Question about Virgin Pulse VP-10 10.4 in. TV/DVD Combo
Ineed code for programming Virgin/Pulse VP-10
I need code for programming Virgin/Pulse VP-10 into my Dis Network remote
  • 1070 Answers
SOURCE: Remote control
check maybe they have a original remote for your tv.good luck.
Posted on Mar 01, 2010
0 characters
1 Points
Virgin pulse vp-10
Sep 08, 2012 | Virgin Pulse VP-10 10.4 in. TV/DVD Combo
Need tv codes for a memorex mltd3222 tv/dvd combo for my direct tv remote
The Dish remote like others only has about 50 possible codes in it--these combo units use odd codes so that remote may just not be able to be programmed for this unit---the remote should have a search mode that allows you to try one at a time every possible code it contains.
May 16, 2012 | Combination Televisions
I need to find out what the remote access code is for this device so I can program my dish network remote
Hello! My name is Becki Barned, and I am with DISH Network. I have provided some steps to program your remote. Because I do not know the model number of your remote, there are a few codes to try. I hope this helps!!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
Becki Barned
DISH Network Customer Service
Mar 13, 2011 | Sylvania SRTD413 13 in. TV/DVD Combo
Dont have the remote and need to set channel to sync with dish network
Try programming the remote to your tv this link will show you codes and instructions.
Hope this helps!!!
Daniel Busa
Dec 25, 2010 | Sylvania SRCD227 27 in. TV/DVD Combo
This tv model does not have a Menu button and I'm using a programmed Dish Network remote that allows me to do everything but access the tv's menu. I need it to program channels. Is there any other way to...
Go ahead and try to readdress the remote for the tv again.Some codes will work for certain features for the tv, but not all features work. So just try to program the remote again using the link below. I hope that if you don't have this resolved, that this helps.
Becki Barned
Sep 30, 2010 | RCA T25061GY 25 in. Combo
Remote control
Mar 01, 2010 | Virgin Pulse VP-10 10.4 in. TV/DVD Combo
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Virgin pulse 10inch tv dvd player
you can use any A/C cord that happens to fit the TV. Use a universal remote, if there are no good codes for the TV then you'll have to use buttons.
Dec 09, 2008 | Virgin Pulse VP-10 10.4 in. TV/DVD Combo
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Virgin Pulse VP-10 10.4 in. TV/DVD Combo Logo
Top Virgin Pulse Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Virgin Pulse Combination Television Expert? Answer questions, earn points and help others
