Question about Mitsubishi WD62628 62" Projection HDTV
Any idea as to why my WD-62628 does this
I have owned my mitsubishi WD-62628 for about a year and it has been pretty good. From time to time it would start to show funny lines but would also fix itself after a few minutes and has not done it for about three months. It started acting up again over the weekend and has not gone back to normal. Any advise would sure be appreciated.
I posted some pics of the problem on my home website:
http://www.scotthenshaw.com/tv.htm
Thanks,
Scott Henshaw
  • 6 more comments
  • scotthenshaw Jan 21, 2008
    When it is just a blue screen, there is a thin vertical strip of lines, (Sort of like a long thin bar code". When has a picture then it looks like someone ran a comb throught the picture and parts are spread all over the place. I posted some pics on my webite:
    Thanks... Any other ideas?
    I tried the unplug test several times and no change.
    I wacked it in the back, (Not to hard) and no change.
    The link that you sent did not seem to work...
    Scott
    Any other ideas?
    I live out in the sticks... Only techs in my area charge more to come out and labor than the TV would cost to replace....
    I actually already have the service manual...
    thanks
    I already have a service manual and will spend some time tonight some of the service adjustments called out on page 44...
    Genius:
  • 1,665 Answers
There is a service manual at the link below:
http://www.nodevice.com/user/register.html
it costs only $9.99 for one month.I think it would be usefull
Posted on Jan 21, 2008
    President:
  • 4,402 Answers
Look for bad caps
http://www.auctioncreations.com/wd62525a.JPG
Picture of bad caps
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
  • 2,427 Answers
Get a technician to have a look at your vertcal controll circuit, especially the capicators, you may have some cracked solder there..
  • 1 more comment
  • Rishi Roshan Ali Jan 21, 2008
    It could also be the vertical or horizontal controll ic, but hopefully it isnt.. If it happens only when watching tv it self (like a station) it could also be the internal tuner..
    trust me you will need the tech unless you wish to purchase the service manual for it.. If you want the service manual use google and google your tv brand model service manual, but it might cost more than a tech
    Well if you have the service manual, just follow the instructions on trouble shooting the VCC AND HCC and you should be fine,, BTW use a good multimeter.. If you need help doing this let me know
    Genius:
  • 1,067 Answers
Here are my two suggestions:
ONE: Do a hard reset. Maybe twice. Unplug the power cord and leave unplugged for 4 hours or overnight.
TWO: Give it the whacking test. This will tell you if you have loose connections or cold solder joints acting up.
http://www.neato.org/~page/mitsu/service.html
The above site is a procedure on entering into the service mode for Mitsubishi sets.....
  • nick helpap
    nick helpap Jan 21, 2008
    Yes, it could be high voltage, but I am thinking more along the lines of the vertical deflection system. You mentioned that you had a blue screen, then a blue line across the top before it went totally kaput. This is an indication of the vertical deflection failing.
    Therefore, I think that is the place to start. My first suspicion would be the vertical amplifier; next suspicion would be the power supply section feeding the vertical section.
  • nick helpap
    what about new lamp
    Guru:
  • 1,894 Answers
What lines are you seeing?
  • 1 more comment
  • dewan nafees ahmed Jan 21, 2008
    seems like the screen is dying up.. i ahve not seen this occuring it in TVs.. this probelm has started in my computer screen also.. anyways you can rate me as thanks and let some one else try ths question..
    as far my knowlwgde it seems like dying screen
    thank you sir,.. and sorry ...good luck
    if its a DM board repair i can send you more help VIA maill.. thank you
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
Mitsubishi tv model wd-62628
It's most probable that you have a ballast issue, it might not have enough power to keep up with the new lamp. That's why you don't get any image.
Aug 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
No picture after changing lamp, tv will not power up.
Try bringing up the menu. If you can't I'd suspect the fmt board if you can suspect the dm module.
Bill
Nov 24, 2008 | Mitsubishi WD62628 62" Projection HDTV
WD-62628 Mitsubishi DLP
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Oct 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
235 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
