Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine
Problem for Starbucks Saeco Italia Digital Barista Fully Automatic...
Saeco italia error
By stoddmi on Jan 21, 2008
I have a saeco italia (not digital) coffee maker.
It's about 3 years old, and yesterday it started flashing it's primary warm up lights and the water light. Now they flash continuosly. Is there a way to reset the coffee maker?
Same Problem
Feb 10, 2008
-   I have exactly the same problem as described. There are some suggestions here: http://www.jlhuffordmania.com/forums/view_topic.php?id=59&forum_id=2
Although none of them worked for me.-   Guest
Solution #1
posted on Jul 07, 2009
Not Rated)
espressofixr
Rank: Master
Rating: 91%, 8 votes
Does water flow from the steam wand when it is opened? If you have not descaled the machine, it may need that done. The water sensor may also be plugged. This would need a service that may be something for a repair center.
Was this helpful?
Yes
No
Solution #2
posted on May 21, 2009
Not Rated)
bansheracer
Rank: Guru  Kitchen Appliances  Expert
Rating: 93%, 179 votes
What happens when you open the knob on the right? It may just need priming.
Comments:
May 30, 2009
- Hi
Check to see if your water tank is all the way seated on the machine. Check to see if a bean is under the water tank.
See if your magnet is in its slot in the water tank.
Was this helpful?
Yes
No
Popular Solutions for Starbucks Saeco Italia Digital
Questions and Unsolved Problems for Starbucks Saeco Italia Digital
Do you recommend Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine?
Answer
Answer
The steam knob came off when I turned it to "steam" -- not just popped out, but completely... (More)
Answer
Esspresso mashine ''spazio mod. EK'' what size allen rench to i need to clean the brew heads
Answer
My Saeco Talea Ring Plus is leaking water from underneath. I seams like it comes from where the milk... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Starbucks Saeco Italia Digital...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
