This instruction works for most any dryer--- it should for yours too:
1) The big trick for a dryer belt is getting it around the drum... the rest is easy. You'll either take the top off and work with the drum to ease the belt around the drum- the front of the drum simply rests on slides/rollers depending on the model
You may need to remove some piece from the front to make this happen too-
2) re-fit the belt then by first taking the inspection cover off (or the whole back of the unit) and working the belt to the back of the drum, near to the pulley and the motor...
3) then, work to unload the spring, place the belt around the pulleys (it should be pretty obvious how to do this) and then release the spring mechanism--- this will tighten the belt between the drum and the drive pulleys.
Good luck!!!
