There is not a reset button on a TA-624 or newer Panasonic, which is consistent with when the 7731's were first delivered, but there is an ON/OFF switch.
Your description is a bit confusing. You press HOLD to put the outside line on hold, which would give you internal (intercom) dial tone. If you have a PAGE key (we like to use the upper right button) press that, or dial the page code, make your announcement and hang up.
There are some page transfer codes and some pickup codes mostly involvine 34 and 43, and those are covered in the User Manual. The feature you descrobe above seems to be from using the TRANSFER button instead of the HOLD button. Pressing the PAGE button without HOLD may give you the same symptom.
Carl
Testimonial: "thanks for getting back to me on this"
