Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Thermostat ct87b My heat system shortcycles and never reaches the set temp.
  • Anonymous Nov 22, 2008
    I have about the same problem, but mine is turning on every few minutes. It does reach the temp it is set for but it tuens on every few minutes. How do I adjust mine to not do this??
Your thermostat could be shutting off too soon. What you have to do is take the cover off of the thermostat and look at the bottom right side of the unit. There will be a Zinc plate with little dashs and numbers on it. on top of the plate is a copper triangle, that is what turns the heat off at a certain temp. The triangle is probably out of place and is cycling the heat off before it reaches your set temp. Just carefully adjust the triangle tward the lower left side of the triangle (alittle but at a time) and hopefully that will fix your problem.
Posted on Jan 23, 2008
Caravan does't reach operating temperature
No one ever said new means good. Try another thermostat. Make sure it is the recommended temp for the vehicle. I would spend the extra money to buy a dealer thermostat. What controls temp is restriction of flow thru the system until a set temperature is reached and the thermostat opens. Has to be a thermostat.
Dec 31, 2013 | Dodge Caravan Cars & Trucks
What are the numbers on the metal strip on the inside of my thermostat from 1.0 @ the bottom too .2 at the top it has a bronze sliding clip with point on it I moved it and not sure if my temp setting
You shouldn't be messing around inside the thermostat. You have now changed the setting on the heat anticipator.This control is used to set the heat, so the heat shuts down before and in anticipation of the heat reaching its set point so it doesn't overshoot it. This thermostat will have be to reset by a pro. I believe it would be cheaper to just buy a new digital thermostat.
Jun 21, 2013 | Intertherm Heating Cooling System 15kw...
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
TEMP IN HOUSE DOSE NOT REACH TEMP SETTING HEATING MAYTAG 5 TON WITH 10 SEER
you need to be more specific here.
If you are not reaching the setpoint (given the setpoint is normal range), then you most likely have an issue. Either the system is not running at max capacity or the system has experienced a failure.
If your setpoint is extremely high (above 80°), then the biggest issue is operator error.
Set your thermostat to 70° and see if it reaches and satisfies. If it does, slowly increase temp to get an idea of where its having trouble. If it doesn't.....call for service.
Jan 07, 2010 | Maytag Heating & Cooling
Heat and air do not shut off at set temps changed thermostats same results
How far off is the temperature when it shuts off, and when it turns back on, from what you want?
Are there any drafts coming through the wall where the stat is mounted?
Dec 18, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
131 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
