Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Lynksys wireless G router
I hooked up my wireless G router and sent it to my other computer which has a wireless-G usb adapter. The computer tells me that the computer is connected and the signal strength is excellent 11mbps, but will not connect with the internet. We took it to someone who reinstalled the driver and linked up with his computer just fine. It still didn't work when I hooked up here at home. Don't know what to do next.
Thanks,
Randy
  • 1 more comment
  • flex1313 Jan 21, 2008
    I have dsl and I just went through setup again with same results. I feel the problem is with the wireless G router
  • flex1313 Jan 22, 2008
    I've done all the things that you have talked about. I even did a check over the phone with my dsl provider and he had me do the run, config., ping etc. Thant didn't help. I think I will take this router back and try a new one and see if that helps. If not I'll have to try something different.
    Thanks
  • networkmagic May 11, 2010
    What type of Internet service are you using? DSL?? Cable?? Is the WAN port on your router properly connected to the DSL or Cable modem with CAT5 ethernet cable??
    Problem Solver:
  • 8 Answers
Pls check the wan port if its connected properly sir...try to ping a site.. pls click on run tab on the start button then type in "cmd" you will see a pop up window. then type in ping yahoo.com if you will get a replies that means your connection is good but if not try to check your wireless-g usb adapter if its working properly. if still its not working try to reset the router and try again with the set up.. check on the lights of the router if it is solidly lit for the wan and 1234 ports.. if it is solidly lit your good to go. go back again to the command prompt then type in ipconfig if youll see a valid ip address go to the set-up page of your router and try to configure again your router.
Posted on Jan 21, 2008
Can i upgrade my network adapter on lifebook A6025 to 80211.N?
To upgrade to wireless N you would have to use a wireless N usb adapter from like lynksys or netgear
Jun 28, 2014 | Fujitsu LifeBook A6025 Notebook
Have a computer with a new lynksis wireless-b router. i am running windows xp but dont have internet to the computer (minus the wireless) how can I install a driver with no cd or internet?
If you do not have the drivers on media, then you will have to obtain them first. Can you temporarily hookup wired and get them downloaded? or use a usb flash drive on another computer to access and download the drivers...
Apr 14, 2010 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
We have a lynksys router. It is 2 years old.
upgrade the router to the latest version of firmware and reconfigure the same.
Also remove the existing saved connections from ur computer and then readd the new connections after reconfiguration of the router.
Jan 11, 2010 | Linksys WRT54G Wireless-G Broadband Router...
I have bought a wireless adapter to get xbox live, but i don't know what to do next. what do i do?
you will need a wireless router and hook the wireless adapter up to the back of your 360 and you should be good to go.....the best router to go with is Lynksys model # wrt54g
Aug 07, 2009 | Microsoft Video Game Consoles & Games
Problem connecting adapter with wireless router
Open router site by giving IP. http://192.168.1.1 in your Browser
Config. your router from setup the enable network router will attain gateway IP Auto. Save the changes. your internet will be connected.
If your problem is solved donot forget to rate.
Thanks.
Jul 20, 2009 | D-Link DWL-G820 802.11g/b Wireless Gaming...
I'm having trouble linkingto the internet from my Computer, whihc is connected wirelessly with a USB Adapter from Lynksis Compact Wireless- G USB Adapter. Basically it connects fine with my router, which...
Double check your router settings to make sure your USB wireless adapter is permitted to use your wireless connection. You will probably find this under wireless security settings. I set up my wireless routers to only allow mac addresses of devices I specify, to prevent drive-by or neighbors using my connection.
Dec 26, 2008 | Computers & Internet
Cannot Communicate from Computer to Computer
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Gus
Nov 18, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Hooking up wireless router and adapter to share wireless
See first if your adapters are compatibles.
You will find help about how to set a wireless network here:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Let me know if you need additional help.
Have a great day!
Pablo :-)
Oct 17, 2008 | Computers & Internet
Internet connection
The only way to replace the network card is to replace the logic board in this unit, however if you are running 10.5, you can purchase an external USB to ethernet adapter at a local Apple retailer and you can hook the computer to the network through that adapter
Sep 26, 2008 | Apple iMac G4 Desktop
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
