Question about HP Photosmart C5180 All-In-One InkJet Printer
Replacement of ink cartridges
I replaced the yellow ink cartridge and my printer says the yellow cartidge is empty.
    President:
  • 4,402 Answers
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Posted on Jan 24, 2008
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
MX700 Will not scan with an empty ink cartidge?!
I just came up with the same problem. But if you keep pressing the right most button (the red one) for 5 seconds the message "replace ink cartridge" disappears and then you can use it as a scanner.
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
We have brother 3 in one first said needs ink yellow so we did
It is recommended to change the cartidges together, however if one of the cartridges still has ink in it, you do not have to replace them together. The printer may still print with an empty cartirdge but if you are printing something in color it will print without the missing color causing the document to look funny. Hope this helps.
Nov 29, 2008 | Brother Multi-Function Center MFC-240C...
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
