Question about GE GSS25SGSSS Stainless Steel Side by Side Refrigerator
GE GSS25SGRE My frig has a high pitched humming noise that comes and goes. It drives me crazy. Any suggestions?
  • Anonymous Apr 23, 2008
    Yes I have the same problem, and seams to be present even in the new ones (mine is only 2 years) and this after I exchanged one in the first week for the same reason
  • nwinters Jun 25, 2008
    Mine is GSS25SGRBSS and the high pitched hum is coming from the fan in the freeaer compartment that circulates the air. I was hoping someone had already solved this problem; it also drives me nuts. I thought it might be the velocity about the fan produced by the plastic shield, but tried different % blockage to no avail. Nothing in the housing seems to be loose, either.
It is not the freon:
http://www.selfhelpforums.com/archive/index.php/t-11409.html
Posted on May 31, 2008
  • 92 Answers
Does it make the noise when the compressor turns on and off if so its from the sealed system and it is considered normal by the manufacture only thing that has ever worked for me(10% of the time) is to add freon or nitrogen to the sealed system.
Posted on Feb 10, 2008
6ya staff
SOURCE:
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
I think there is a high pitch noise coming from a new kdl46ex520 is this common for lcds
Actually, yes, this is common for lcd tvs. I have a Vizio Internet Apps TV that does this, and it is normal.
Dec 12, 2011 | Sony 46 KDL46EX520 LCD TV
High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Mar 27, 2010 | Frigidaire FRS26RLECS Side by Side...
Neighbor's kerosene tank makes horrible noise at night
The oil lines that run from tank to furnace is acting like a guitar string. As oil is being pumped through the pipe, it is humming. Try placing an old rug on the tank to see if it absorbs the hum.
Jan 22, 2010 | Reddy HEATER RH125T 125,000-BTU...
Kenmore refrigerator has loud high-pitched noise problem
I would suggest calling sears repair ( this refrig is still under warrenty ) and have them come out to check . If they say it's normal , tell them you want the refrig replaced . You do have rights with a new product not working to your standards .
Sep 19, 2009 | Kenmore Refrigerators
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE FRIG Model GSL25JFPJBS
my ge fridge has a hi pitch sound.
I hate it
Aug 14, 2008 | GE Refrigerators
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Same humming/whirring sound from freezer
sounds like the evaporator fan motor is on its last legs. that is the part i would check.
Sep 25, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
GE GSS25SGSSS Stainless Steel Side by Side Refrigerator Logo
350 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
