Question about Panasonic PT-47WX53 47" Rear Projection HDTV
No Picture only sound
I only get sound with a black screen and a bluish/purplish line down the middle of the screen (horizontal). This TV is about 5 almost 6 years old.
  • lilflaca Jan 24, 2008
    I received your suggestion, and then noticed that the TV wouldn't start. All I get now is a red blinking light - won't power on, no picture and sound. What could it be?
  • Panasonic Master
  • 8,617 Answers
You have a problem inthe horizontal deflection circuit. Quite possibly a solder connection around the yok plug connection or the horizontal output transistor or Driver transformer. If the solder looks good. You will need a service manual so you can check your various power supplies. You can get a manual at the following link for 10.99 and they also offer free support. They willals email it to you if you return to the site and request that they email it instead of mail. Hope this helps. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jan 21, 2008
  • Sonny Berry
    Sonny Berry Jan 24, 2008
    You are defiantly having a problem in your horizontal deflection circuit and it has shut your tv down. Without the service manual there is no way to properly diagnose it. The service manual will give you the various components to check for proper voltages to pinpoint what your exact problem is. I would recommend that you get the manual in the link I posted above. They offer free support with the manual to help you figure it out Without the manual you are only shooting in the dark it could be something simple. Usually its one component and that will shut your set down. First it will exhibit a symptom like loss of picture and then it will go into complete shutdown. Hope this helps.
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Problem with tv
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Jan 05, 2008 | Toshiba 36A41 36" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
