Question about Syntax SV400 Motherboard
I need latest bios for this sheet
Syntax sv 400 , bios crash , i have the eprom writter
thanks
  • 2 more comments
  • babanac Jan 22, 2008
    It was good, now I have the mobo back
    Thanks a lot!
  • Anonymous May 03, 2008
    the link is not working
  • Anonymous Feb 27, 2009
    "No web site is configured at this address."
    Does anyone have the bios file?...
    Can you uploaded somewhere on the net ?
    Thanks a lot.
    PS also if you have the flash programm.
  • thomas921 May 11, 2010
    Hey,im looking for the same bios for Syntax SV400.
    The file N4a3831a.bin is down ;-(((
    I need the bios because amd sempron 3000+ are not support.
    Have anybody the file ore know the problem with the cpu?
    greetings
    Thommy
Wo????
Posted on Aug 09, 2008
    President:
  • 2,351 Answers
Syntax SV400 bios The file N4a3831a.bin is dated 2004.
http://64.168.125.230/support/Syntax/Motherboard/SV400/Bios/
Luck!
Vote....
Posted on Jan 22, 2008
6ya staff
SOURCE:
I have a desktop dell I have a problem with my system startup it shows a massage which is (cmos checksum error defult loaded) and I can't press F1 the keyboard also not working so what should i do to...
I think you have a corrupt BIOS, try changing the CMOS battery first of all
if the computer is unusable (you dont get any further than this error) you may have to remove the bios chip and reprogram it with the latest bin file and an eprom programmer.
if the computer is operational, try installing the latest bios by following the instructions upon download.
Mar 17, 2011 | Computers & Internet
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
I deleted my bios how do i install my bios
The software in the BIOS is stored on an EPROM (Eraseable Programmable Read Only Memory). So, buy some hardware, namely an EPROM writer, remove the EPROM chip from the motherboard, insert the EPROM chip into the EPROM writer, download the latest BIOS-software from IBM's web-site, and load the software onto the EPROM writer, and rewrite the software onto the chip. Remove the chip from the EPROM writer, and reinsert it into the IBM motherboard.
Jul 17, 2010 | IBM NetVista PC Desktop
MANUAL OF MOTHER SYNTAX Olevia Sv 266 M
go to syntax web site download driver and manual jim
Mar 07, 2010 | Computers & Internet
hi
try to download the drivers from this link,
http://members.driverguide.com/driver/detail.php?driverid=350127
you have to register first before you can download.. it's free..
May 09, 2009 | Syntax SV400 Motherboard
I can't configurate my bios version k7s41gx. Please help.
you cant configure your bios version thats something thats programmed into the EPROM or flash memory on the motherboard you can update it using the utility and latest firmware from your motherboard manufacturers website to add functionality or features to your motherboard ie so you can use larger hard drives or that sort of thing.
Other then that the version of your bios is just to let you know what version you have so you can establish if you need to update it or if its the latest version or not.
Apr 21, 2009 | Network Associates Computers & Internet
No sound
This web site has drivers for the S651M Motherboard, including an Audio Driver for WinXP:
http://usa.aopen.com/download.aspx
Apr 04, 2009 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Bois problems????
No - this is something that can generally only be resolved with a repair install of the XP.
The repair option can be accessed while doing a standard (i.e. boot from the CD) install. Note: this is a repair option after you select to install; not the repair/recovery options on the first screen.
It should detect your OS and ask if you want to repair it. This will cause you to have to reactivate windows, and I highly recommend having your drivers already downloaded and ready to be installed. Some programs my have to be reinstalled also.
There is a sysprep tool that can be used, but I've always found it easiest to do a repair.
May 07, 2008 | Syntax SV400 Motherboard
Dvd writter not working
if the device is set up as a master and not a slave device it may be interfering with the hard drive. check the jumpers on the back of the device. If it's plugged into the same cable as the hard drive it must be a slave device. Otherwise, check your bios upon bootup to see if you it's trying to boot from the device instead of from the hard drive.
Nov 29, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
Syntax SV400 Motherboard Logo
320 people viewed this question
Top Syntax Computers & Internet Experts
Ekse
Robert Salgado
Robert Salgado
Eric Sutherland
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
