Printer will not work
The inking mechanism will not move in either direction, therefore it will not print.
  • 95 Answers
I would say that something inside is either broken or jammed. A lot of the older injets had a rubber belt inside that moved the print cartridge. I don't know where you would find a replacement.
Posted on Jan 21, 2008
6ya staff
SOURCE:
Why are the epson workforce printers better? lower ink costs?
Considering reviews I'd say price vs quality will make diference...
Also, you can buy ink cartridges for as low as 1 Usd each (recycled).
Nov 17, 2014 | Epson WorkForce Office Equipment &...
A child moved the head in my Epson Stylus Printer
Turn the printer off -- listen for noise as the head should move to its "parking" position.
Turn the printer on, and listen for noise.
If none, then the mechanics that move the head are broken.
Is the printer still under manufacturer's warranty -- although the warranty may _not_ cover child-inflicted breakage.
Sep 18, 2009 | Epson Office Equipment & Supplies
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
My epson C62 died while I was printing a document. The red light is on, green light off. the ink containers do not move entirely to the right where they belong. Does not respond to any signal.
This indicates a so-called "fatal" error. Because your print-head cannot fully move into its parking position on the right, it seems likely that the parking mechanism has come adrift. Turn the printer on, and as soonas the print head tries to move, pull the power cord out of the printer. You should now be able to move the print head (gently) out of the way and see into the parking area. If there is a plastic rod sticking up, ull it gently towards you and it should snap down out of the way. The printer should now work. If the problem re-occurs, it means the mechanism is clogged up with dried ink. Try repeating the above process a few times to see if it clears it.
If you see that the whole parking mechaism has come adrift, this almost certainly means the front spring has come off. This will require the printer to be dismantled I'm afraid, so will cleaning the print mechanism. Service Manuals are available to help with this.
Report back on what you find
Jan 13, 2009 | Epson Stylus Photo R220 InkJet Printer
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
After cartridge change, the printer will not work
you might not like it, but here it is, it is the truth
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Aug 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Can't install new ink, can't do anything
open the cover of your printer and ink cartridge will move to the left therefore allow you to change your ink
Apr 16, 2008 | Brother MFC 3100C All-In-One InkJet...
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Open Questions:
Computers & Internet Logo
290 people viewed this question
Ekse
Marvin
Marvin
