Question about ASUS P5RD1-VM Motherboard
No booting is possible
Mother board led is not glowing & booting is not possible
    Problem Solver:
  • 14 Answers
First of all check the power cable than all connection than the SMPS
Posted on Jan 23, 2008
    Problem Solver:
  • 6 Answers
First of all see that the switch of SMPS is on if yes then replace the SMPS
  • 226 Answers
Check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Posted on Jan 21, 2008
  • earl llanera
    earl llanera Jan 23, 2008
    y is it inappropriate?
No video at all, no boot, unable to get bios boot setup, green light comes on but no boot, even with a FDD boot disc. Disconnected HDD and inserted boot FDD, no joy. M/B Asus A8V
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Aug 17, 2009 | Intel D865GVHZ Motherboard
Pwr/slp/msg led not glow but the hdd led is always on
hi im josh in cebu phils. may i help you? not open or no boot. If it doesn't boot or power on and no prsence of current on your pc. The main problem is motherboard. it may be no current is running on the board.because the supply chord was lost or not enough supply to make the motherboard execute.check if your power cable 16 pins is connected and the 4 pins 12 volts power support.if it loosen thats the problem. Sometimes the compatibility of your processor and the mainboard is needed.if both of these is for the first time check the compatibility of the mainboard and the processor in your support manual. good luck!
Feb 20, 2009 | EliteGroup P4M800-M7 Motherboard
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Mother board D845GVSR
hi im wesley. does the pc boot up at all?
Jul 09, 2008 | Intel D845GVSR Motherboard
buy an AK-47 assualt rifle then carefully mount *********** board on top a table with a clamp then move back for about 8ft away **** that AK-47 with a banana type magazine load in it like a damn guerilla terrorist that you are and fire away like a mad man... then buy a new pc wala your problem is solve hehehe BWAHIHIHIH NYAK NYAK NYAK
May 25, 2008 | EliteGroup K7VMM Motherboard
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Apr 18, 2008 | Intel Motherboard
ASUS P5RD1-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
