Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How to replace a switch-lid on a whirlpool washer
How can i get a diagram of my washer to pull the lid of to replace the switch-lid
  • 5,911 Answers
You can check various appliance repair websites for self help manuals, or you can follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Have you purchased a lid switch yet? Most major appliance repair centers carry them. The price is about $35. If you have not purchased one yet, let me know what your EXACT model number is (located on the rim of the wash tub opening under the lid) and I will locate a part number for you. I hope this information helps you.
Posted on Jan 21, 2008
Top loading lid switch does not work. hitting the lid (when closed) will start cycle. How do you access this switch for replacement?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Feb 12, 2011 | Washing Machines
When lid is closed,the switch is broken and washer won't start.how do i raise top of washer to replace swich??
Jan 16, 2011 | Washing Machines
Want to replace the spin cycle switch that is activated when the top lid is closed. How do I get at the switch? Thanks.
Dec 10, 2010 | Kenmore Washing Machines
My kenmore ultra fabric care heavy duty 80 series model 110 will not drain. The problem occured after a heavy load knocked the lid switch off during the spin cycle. How do i fix this/replace the lid...
Nov 05, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series #11020722990 how to open cabinet and replace lid switch?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Aug 10, 2010 | Kenmore Washing Machines
Have to trip washer lid safety switch with something more substantial than little 'plunger' attached to the washer lid to get washer to drain and spin during rinse cycle. do i need to replace the safety...
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet to replace it.
It comes as a complete unit and you can't replace just the plunger.
May 03, 2010 | Kenmore 23812 Top Load Washer
Sears Kenmore automatic washer model# 110.82872120 (Kinda old) no longer drains. I think it could be the pump or a relay/switch going to the pump. How do I find a schematic to diagnose the problem. I have...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.82872120&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service Manual for these washers:
If it will neither drain NOR spin, the problem points to the Lid Switch.
If it works, the Lid Switch is a relatively inexpensive part.
If it WILL spin but simply won't drain, the problem points to the pump or hoses. The motor directly drives the pump when in spin mode.
I'd pull the cabinet and check the hoses for blockage, and check the pump to make sure it turns and isn't blocked inside.
Apr 19, 2010 | Kenmore Washing Machines
Lid switch replacement
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Mar 30, 2010 | Kenmore Washing Machines
Replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
May 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not spin
Hi, There are several causes for this problem. Check these.
  • No spin at all: the lid switch is fried. You test it with your meter.                                  There will be a motor which spins the washing machine's drum.                                              If you don't hear the motor running, then its the lid switch which would have been broken and needs replacing. A bad lid switch wil interrupt the spin cycle.
  • In the Whirlpool washers, a common problem is that the lid plunger stops making contact with the lid switch. Use a pen to manually press the lid switch actuator (with the lid up, duh). If the washer spins...well, you know the rest.
  • Older (belt-drive) Whirlpool: the spin solenoid is burned out or has cut wires. Ohm out that solenoid (20-30 ohms) and test with a test cord. Make sure the wires are intact by giving them a little tug. If this is OK, you may need to adjust/replace the basket drive.
  • Timer is fried. On older timers, it's sometimes possible to run an external jumper to replace the bad internal contacts. Usually, however, the entire timer must be replaced. The only way to confirm is to use your meter and wiring diagram.
These are the causes that have to be inspected. You can also visit this site www.whirlpool.com/custserv/index.jsp
Hope my info solves your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Whirlpool CAM2752KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
409 people viewed this question
Dan Webster
Dan Webster
Sal De
