Question about Magic Chef CMV1000B Microwave Oven
Samsung over-range microwave does not heat - should I toss it and buy new one?
  • 96 Answers
How old is it, how mutch did you pay for it, keep in mind everything to toss out creats cheap china reproduction and polution. Don't be the first to complain that we have to do something.
No heat may be cause by serveral problem, bad board, switch, magnetron, power supply, thermistor, fuse, door switch levers, etc...
You can look inside to see if the fuse is ok, second check to see when you start it if the primary voltage at the big transformer is there, if it is there then the problem is after the transformer most likely the mignetron, cap or power board if it has any.
Keep in mind if you nothing about the danger involve don't open the unit.
Posted on Jan 22, 2008
Samsung over the range microwave oven model# SMK9175ST the microwave part stopped heating
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Jul 16, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave starts by itself
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
Apr 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave is heating but the fan is not blowing
just replace the shaded pole motor with any other shaded pole motor that you can put in.. new or used
Nov 27, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave oven does not heat
When you press start the light and cooling fan are ON but the Microwave Oven is not heating then the magnetron must have failed. If it is out of warranty it is probably better to buy a new microwave oven.
Dec 29, 2010 | Frigidaire Over-the-Range Microwave
Everything (lighting, hood fan, etc) is working on the microwave except it is not heating. Would prefer to get it fixed than buy a new one.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 03, 2010 | Maytag Appliances Over-the-Range Microwave...
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
Samsung Microwave runs won't heat
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 07, 2009 | Samsung SMH7174BC Microwave Oven
Ge profile spacemaker over range microwave not heating
It was probably the Magnatron tube that went out , they are normally replaced only under warr. due to the cost to repair , the part is roughly 200.00 and labor ranges from 100-200. I guess it all depends on what it is worth to you , you can pick a decent brand new one up for about 200. Hope that helped you out. Phil
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
