You must be sure the SkyCaddie is turned on and connected to your computer. You should then launch the SkyCaddie desktop software that you should already have loaded onto your computer. The two should automatically connect and should take you to your golf course listing on the device. From this list, you can add or remove golf courses to your device by either clicking on the ADD button or the REMOVE button on the list, whichever process you want to perform.
no not really don't know of anyone who just sells side burners plus you would have to be a gas fitter to do it , best to buy a new one with a sids burner ,
One of them new fangled dryers with the fancy electronics. I bet your exhaust thermistor has tripped. Check your vent pipe for proper air flow. Any lint built up at all will cause these new fangled wonders to have a cow. Of course I don't know what brand you have or what type heating system. It don't matter, you have a issue with overheating.
what are facing is a problem caused by a virus that either destroys files that support .exe applications to run or it replaces which makes your machine unstable. my first solution to you is to repair your operating system using the operating system cd. secondly, if that doesn't work please try installing a second os on your system and then you do a dual booting. u then delete the folder of the previous os. if that does not work u backup ur files and then you format ur system with a new os
You can try defragging your hard drive or adding more memory. Additionally I would use an antivirus program and also Malwarebytes Anti Malware (Mbam) to see if there are any viruses or malware slowing down your system. If those don't work you should back up all of your important files and do a full reinstall of the operating system.
It seems your new mp3 player memory is already full, you need to delete other files or songs before you added another. If it is not yet full, try to delete and reinstall other songs. Be sure the file songs you added has no error on it. That the only things you will do, the mp3 player operate normally and trouble come as you add new songs, don't overload it, as it's built in memory will fail. Thanks for asking.
Have you tried a quick reboot? Of course, save the file you want to print, reboot your PC and try printing it again. If this doesn't work, try removing your printer in the "Devices and Printers" that you can find in the control panel (or Printers in XP). After removing, try adding a new printer again. Don't worry, you won't need drivers then because the driver is already in your PC after you installed the printer the very first time.
I hope this helps... (,'')
thats the blue screen of death generally its an issue with ur RAM try taking the Ram out n replacing it as maybe connection error if thats no help Replace it with some New RAM n will fix the Problem
If you can log on to an administrator account you can remove the passwords on other accounts. If you dont know the passwords for any of the accounts you can try ophcrack, which uses rainbow tables to recover passwords from the sam files (where windows keeps passwords, encrypted of course) and let you know what they are. High success rate on XP, not so high on vista or 7. For extra added bonus, its a free open source program.
Adding RAM, especially if your running Vista, will usually cure a lot of the problems related to speed. You shoul dbe able to see quite a difference in boot time and when loading programs in either XP or Vista.
Adding RAM is usually a very easy process. Certain care must be taken of course not to build up any static electricity of course. But after looking at the specs for the Acer Aspire, unless you are comfortable with taking laptops apart, I would take it to your local computer repair place and ask them to install it for you. THe slot is located underneath the motherboard and requires quit a bit of finesse to get to. Also, from the look sof it, you'll only be able to upgrade to 1.5 GB total of ram. So now it's a matter of considering if it's worth the trouble for an additional 512MB of ram. There will be a light improvement, but you'll have to wiegh that against the cost of the ram and installation.
try using another web browser like mozila fire fox or opera. other wise u have to uninstall the internet explorer and reinstall it again. to uninstall in windows(xp) * click on start--control panel. *click on add/remove programs then click on ad/remove windows programs at the left corner of the pop up window. *among the windows components, check for internet explorer and untick it then click on next to continue. *when don restart yr system to reinstall internet explorer *follow the steps above to tick internet explorer thyen next n yr don. it should work i suppose.
