Question about Marshall MG10CD 10 Watt Combo Amplifier
Hi im in Argentina and i accidentally pluged in my amp without an adapter now it doesnt work what needs to be fixd?
    Habit-Forming:
  • 99 Answers
The Marshall MG10CD is internally fused. Unplug from mains supply and check the internal fuse. Replace with fuse of the correct value. If fuse blows again come back here for further advice.
Posted on Sep 20, 2014
  • 506 Answers
The power supply is blown. Argentina is 220V I believe. I have never seen a power supply schematic for this however being that it is low power it is a linear supply not switching. Either the rectifier diodes are blown out or possibly the output capacitors are blow due to approx double voltage. If you try this yourself be careful otherwise get a new amp. Good Luck
Posted on Dec 14, 2009
SOURCE:
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
Mar 24, 2012 | Peavey Electronics Peavey Rockmaster...
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
I havn't used my UM300 in only two days, last time it was working pretty well ... better than ever, today morning i woke up and tried to use it, but all im getting from the amp is a buzz in a very low...
Dead battery or disconnected power adapter. Leaving cables connected discharges battery in a day as this is what switches the battery on. (The input cable)
May 24, 2011 | Behringer Um300 Heavy Metal Distortion...
Hi.why my zoom g1x has no power.im using a universal adator...i am in phillpines.power volts here..220 volts.how is the setting of my adaptor then?
I have a ZOOM GX1XN and it doesn't like universal adapters much. Using one with the wrong voltage or polarity may permanently damage your pedal. Try to obtain a proper ZOOM AC adapter (part number AD-0006 or AD-16) if possible. These are dual voltage and will work equally well with both 220 and 110 volts. Failing that you need an adapter that will give a DC (direct current) output of 9 volts at 0.5amps - maximum 4.5 watts. The outer contact (sleeve) of the adapter needs to be positive (+ve) and the inside contact negative (-ve). Lots of universal adapters are the other way around with the sleeve being negative - but some have a multi-connector on the end with both positive and negative sleeves.
Jan 08, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
My sister has the casio LK 30 for her special needs daughter. She accidentally used the wrong adapter to plug it in and burnt something in the unit. The new casio is too complicated for my neice and I...
If it's blown a regulator in the keyboard you may be lucky that that's all that's gone.... If unlucky it could have rippled through & taken out a lot of the electronics. (aka a right off) A decent repair shop should be able to take a look & give you a price to sort it.....
Jan 12, 2018 | Casio LK30 Note Lighted Keyboard
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Apr 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
It lights up but doesnt put out sound
A friend of mine had the exact same problem. In his case the pedal is only good for hammering nails now. If it still has it warranty I'd say look into that, if not you've got nothing to lose. Open it up, look for unattached wires. Also, try using a battery instead of an AC adapter..
Oct 26, 2009 | Digi-Tech Digitech X-Series Synth Wah...
My echo wont turn off when im on my clean setting
Hi, try holding down the clean channel button when you start up the amp. If that doesn't work, try turning up the delay, then turning it all the way down.
I have the exact same amp and this always works. If this doesn't work for your amp, you may need to take it in.
Dec 28, 2008 | Line 6 Spider Iii 15 Modeling Guitar...
Marshall MG10CD 10 Watt Combo Amplifier Logo
197 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
