Question about Dell Inspiron 6000 Notebook
AC Adaptor Problem
The little thingy where you plug the laptop to the AC is very loose and a little bubble pops up saying my I have a critical battery problem which means the AC thingy isn't working, right? Ok. I called Dell, which is pointless, and they said I need a new motherboard or I could borrow a friend's docking station to see if that would work. Am I really gonna have to buy a new motherboard or do you think the docking station will work? Will I loose the info on the computer if I do have to get a new motherboard? Would it be better to send it to Dell to have it fixed or could I have it done locally? Help!
  • coda1303 Jan 21, 2008
    My local computer guy suggested that but said he did it to his but it only lasted a few weeks. He thinks I'm screwed. How much do mobo's cost?
    Genius:
  • 1,067 Answers
No u can buy the power plug for it u have to take it all aprt tho like mobo out then un solder the ac jack install new one from ebay 4 bucks ok
Posted on Jan 21, 2008
  • nick helpap
    nick helpap Jan 21, 2008
    i would try that docking staition thats good thing to have if it work work set it on that for few hours get battery on
Laptop is charging but cant turn on
When you say "you fixed the thingy" (ac jack), how did you fix said "thingy", did you open the laptop and replace the damaged/broken "thingy"? Need more info. Perhaps the "thingy" isn't fixed? Try remove any DVD,CD, USBs from the laptop, removing the "thingy" , remove the battery, Hold down the on/off button for 10 seconds, replace the battery, replace the "thingy" push the on/off button. That said, When you fixed the "thingy" was ALL power removed from the laptop AC plug, Battery, If not a short may have occurered.
Nov 06, 2012 | Lenovo G470 Core I5 4gb 500gb Hdd Laptop...
AC Adaptor not working in laptop
the problem is in your laptop...maybe it damaged too when you plugged your old adaptor. you should check your laptop for a repair...maybe it needs to replace tha spare parts that may have been damaged.
Dec 01, 2011 | Computers & Internet
Acer laptop will not boot up
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Acer Aspire 5610-4648 Notebook
Why doesnt my laptop turn on ??
Dead Laptop.
Hope this helps.
Nov 22, 2010 | Computers & Internet
Power button blinking, no display light.
Dead/ish Laptop.
If the adaptor is fine and the laptop still won't start, then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 16, 2010 | Acer Computers & Internet
DELL 1525 laptop boot issue. When switching ON it shows only blank screen. Grateful if you could help resolve this issue
Have you got an external screen you can plug in to prove the video? Try this check list:
Dead Laptop.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Dell Inspiron 1525 Notebook
Acer battery no charge/plugged in "battery is criticically low"
This is a tricky issue, it's either a problem related to the battery or the adaptor.
Try removing the battery and just plug in the adaptor and see if the computer will boot. If it does then there's a problem with the battery and you just need to replace it, if it doesn't then there's a few other things it could be.
The two most likely options is that the adaptor is bad, or the AC port on the computer has become loose. Most of the computers I've repaired that had these symptoms was that the AC port was bad if the battery wasn't. The best way to test this is to plug in the adaptor and just see if it wiggles around a lot, if it's loose then it might not be connecting to the board correctly and will need to be soldered bad on. If it's not loose then the adaptor might be bad, you can test another adaptor on your laptop or that adaptor on someone else's but be carefull, I can't stress this enough, if you're going to switch adaptors you have to make sure that the voltage IS EXACTLY THE SAME and has the same amps, if the voltage is off you can damage the computer, if the amps is off you can damage the adaptor.
If by some fluke it doesn't seem to be the battery, and you tested the adaptor and the AC port doesn't feel loose, then the charging circuit in the laptop might be shot, in which case you'll need a new motherboard.
I think that covers everything, sorry for the wall of text
Mar 01, 2010 | Acer (56.04200.H22) (5604200H22) 200-Watt...
What is the ac adaptorfor sdr-h40
It's the little black box that's got "Panasonic AC Adaptor" written on it. It looks a little like a power brick, but you can put a battery into there. (You also need to plug in the DC power cord, which goes into the same compartment on the camera as the battery does. It looks like a battery with a cord.) Hope this helps.
Jul 11, 2009 | Panasonic SDR-H40 HDD Camcorder
Wireless mouse won't work
Perhaps try the device manager.(click) My Computer>Manage>Device Manager.
Feb 22, 2009 | Sony Computers & Internet
Dell Inspiron 6000 Notebook Logo
90 people viewed this question
Alun Cox
