Question about Neff T1323 Electric Cooktop
Wiring in a hob
Hiya. Just bought a new hob and husband has always wired them in in the past. NEFF does not seem to supply wiring diagrams with their hobs in order to get us to shell out another £50 to get an electrician in. I don't need you to tell me how to do all the wiring if it goes against your concience, but could you just simply tell me which of the following is for UK connection? A choice of only three. N1, N2 and N3. THE MODEL IS ACTUALLY THE T1213X0, not listed in your options!
  • RogerM9 Sep 06, 2008
    Have bought a new Neff T1333 ceramic hob and as with "suntrekcats" there is no wiring connection diagram supplied. I assume that to connect to the standard 240v UK domestic supply you just connect the earth as shown, neutral to T5 (which is bridged to T4), and then bridge L1 -L2, L2 - L3, and connect the live cable to L3. Can anyone confirm please? I'm sure this is not rocket science! This way neutral connects to terminals 4 and 5, and Live to L1, L2 and L3.
SOURCE: Safety lock on Neff hob
to deactivate mine is as follows (copied verbatim from the manual)
to deactivate the childproof lock is the reversal of setting it -
turn all four hotplates to setting 2
turn off all the hotplates in order from right to left
touch the main switch for at least 5 seconds, once the five seconds is up you will hear an accoustic noise.
it is now deactivated
to turn it on with the childproof lock on you have to touch the main switch for 4 seconds
Posted on Sep 29, 2008
SOURCE: Neff Hob
Hold the power button for a few seconds
Posted on Nov 01, 2008
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
Posted on Feb 06, 2009
  • 222 Answers
SOURCE: How do i unlock my neff hob? Red key above on/off
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
Posted on May 29, 2009
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Jun 09, 2008 | Cooktops
Neff T1323 Electric Cooktop Logo
693 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
