Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool Ultimate care II
The machine fill with water but does not spin in the wash cycle or any other cycle. Please help
  • 4 more comments
  • Muddley Jan 24, 2008
    I have the same problem.
    The machine seems to go through the cycle as normal but it does not drain the water out.
    Is this a pump issue or a blockage??
  • Muddley Jan 27, 2008
    I have played with the machine at length today... In the hope that if this was merely a blockage, I could move it...
    If I go to a spin cycle, the machine begins to work normally, bringing in some water and then spinning slowly... It seems then, that the pump does not engage, thus leaving the water in the drum and not allowing the machine to speed up to a full speed spin.
    If I enpty the machine using gravity to drain the water, the spin runs normally.
    Obviously draining manually is not viable during a wash cycle. Is it possible that there is a switch for the pump, which is in need of replacement, or is this a requirement to replace the pump.
  • melindadale Feb 24, 2008
    I have a Whirlpool Ultimate Care II Model LSQ9544KQO. It will fill,
    agitate and drain correctly in any and all cycles, but it will not spin
    in any cycle. Sometimes I can manually "push" it and it will start to
    spin slowly, with light loads. Also the machine is leaking from under
    the front. Please help. Thank you
  • edv7028 May 11, 2010
    Hi...
    My washer, (Just two months after the extended warranty ran out), will intermittently NOT Drain the Water or Spin. If I lean the machine back and drop it, it will usually continue to cycle to end; but not always. It only handles Small Loads now; but sometimes not even a small one. I often have to drain the water from the machine before it will again empty the water and finish a Rinse/Spin Step.
    I don't think this is a mechanical problem; but maybe a relay somewhere. Can anyone tell me where and how to look ? Does anyone know if it's a relay that kicks-in the Rinse/Spin Cycles ? Can anyone provide me with a Logic Diagram for this machine; and maybe even a schematic ?
    Thank You !
    Ed VA
  • robert samples May 11, 2010
    does it agitate in the wash cycle
Posted on Jan 27, 2008
  • Muddley Jan 28, 2008
    Yes, but am not sure what I am looking for... Is it possible that the pump could be blocked and just need cleaning... or is it more likely to be dead???
  • 770 Answers
Your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
Posted on Jan 25, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Jan 28, 2008
    Ok now your problem is clearer you have a bad pump or something stuck in it there is no switch besides the lid switch and that is working by you telling me it is spinning do you want to open the unit to replace the and check the pump??
  • Muddley Nov 29, 2013
    I know it's been a few years, but we still have the machine and I thought it would be good to close this.
    There was a childs sock jammed into the pump impellar. It was not possible to remove it, but the pump was cheap and simple to replace.
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
The load won't start.
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
426 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
