Question about Epson Stylus CX6600 All-In-One InkJet Printer
Cx6600 plenty of ink but none on the paper ?
Hi i just got a epson cx6600 put new cartridges in it gone through al the usual things but still it will not print
it says that all the carts are full
what am i missing here
other than ink on the paper haha
thanks
geri
  • jkmack Feb 02, 2008
    Plenty of ink but now on paper
  • Epson Master
  • 1,879 Answers
Since u just got it, consult the manufacturer immediately for more warranty options
Posted on Jan 23, 2008
6ya staff
SOURCE:
When i press print, the goes through the motoins but nothing is printed on the piece of paper, and there is plenty of ink the catridges, any ideas??????
Hi with your Epson machine normally its the print head that has dried up and the ink is not able to get on to the paper have you used the head cleaning on the machine? this can help and some people claim that using head cleaning liquid works (I have not found them to be much use)
if you have tried all the above then its down to replacing the print heads and this is not for the DIY person and in the Uk it usually not an economical repair
sorry Ian
Mar 15, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Hi, I have an epson stylus cx6600 , I replaced the black ink and the pages printed afterwards were full of lines, I cleaned the nozzles and cleaned the heads twice. I then took out the black ink cartridge...
Did you put a new cartrige the first time, or just put ink in the old one? Ink cartriges dry out. If you let them sit for extended periods of time, you don't save ink, you let them dry out. You can try to bag and wrap them if you are not going to use for awhile and see if they keep longer...but usually you just have to get a new one. I've heard you can put tape over the end of it to keep it longer...don't know from experience though. New carts will usually do the trick though.
Jan 12, 2010 | Epson Office Equipment & Supplies
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Is there a way to make the eposon cx6600 print when a color of ink is out. I have plenty of black ink and it won't print~
You haven´t any way to do so, if what you want is colour print. You may need to replace cartridges.
Nov 29, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I cant print from my epson stylus CX6600 printer. When the printer picks the paper it comes out plain. No text or pic is printed on the paper.
before installing the ink cartridges, have you removed the yellow tape from the cartridges? removing the tape allows air to flow in the cartridge to release the ink...
Nov 20, 2009 | Epson Office Equipment & Supplies
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My cx6600 has new ink cartridges and acts like it is printing but the pages come out blank!
Try taking a new cartridge out and shaking it ( with your finger over the hole that the ink comes out) and then put it back in.  Also make sure that the tape that is over some cartridges' printing area has been removed.
Dec 09, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson cx6600 printing only magenta even with new cartidges
Try remove and shake the inks and reinstall it back in and test to print. If you have tried more than 4x with the head cleaning it might be your ink pads inside the printer is clogged. Is this still under warranty? You have to call Epson they might help you out with it.
Oct 11, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX6600 Only Prints/Copies Blank Pages. Is there a solution other than tossing this Epson produce failure? [email protected]
This is a common problem with Epsons. With Epsons, they have a printhead that lasts for the entire life of the printer. These problems usually occur when you change cartridges and put fresh ones in and it does that charge. There is a long tube that goes down to a big pad that all waste ink drains into. Eventually, the ink hardens and builds up, plugging the tube. The worst thing you can do is clean the heads. My advice is to buy new, or have a repairman clean the heads with hot chemicals.
Feb 26, 2008 | Epson Stylus CX6600 All-In-One InkJet...
After replacing the black ink nothing prints
Before taking out a new ink cartridge from its package, shake it four to five times. Are you sure you have the proper ink replacement cartridge.The following Epson ink cartridges should be used in your device: * Black: T0431 (high capacity cartridge) or T0441 (standard capacity cartridge) * Cyan: T0442 * Magenta: T0443 * Yellow: T0444 How did you discover the ink was low? Did the machine prompt you or was the printer not printing properly? The other colors should blend together to give you atleast some form of black. If the printer alerted you to change the cartridge...Go back through the procedure to install a new cartrige. Follow the steps below to replace ink cartridges. Make sure the CX6600 is on. When the ink is empty: Refer to the LCD panel message to see which ink cartridge is empty, then press the Color button. When the ink is low: Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, then press the Color button. The ink cartridges move to the replacement position. Make sure that the document cover is closed, then open the scanner unit. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the CX6600. reinstall the same cartridge. (Try shaking it a few times again) If none of the above works uninstall the printer. Download the newest drivers from epson and the should straighten it out. Good Luck. Tim
Feb 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
