Question about Ovens
Dacor double electric oven CPD227
I self-cleaned the top oven w/o any problems.
For some reason, I could not get the bottom oven to self-clean, a "door" message kept showing up on the display even though the door was closed. Now the door is locked and I can't find a way to unlock it.
Thanks for any help on this issue!
Jerome
  • 1 more comment
  • jejeking Jan 21, 2008
    By the way, the door has been locked for 3 days now, so it's not a temperature issue.
  • Fixbill Mar 31, 2008
    I have the exact problem. I tested the high limit -it is fine. I checked the door switch it is fine. I sent e-mail and I am awaiting an answer.
  • zrickstir Nov 01, 2008
    I have a cpd227, can not find anything online from Dacor. The bottom oven's door will not open, how do I find information on this set, and how do I get the door open
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
  • 91 Answers
SOURCE: Dacor ECD230 Sabbath Mode
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
Posted on Mar 25, 2008
SOURCE: Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Posted on May 19, 2008
  • 29 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
Posted on Nov 24, 2008
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
Self-Clean door lock will not dis-engage.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | Dacor ECD230 Epicure Stainless Steel...
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
My Dacor ECD230 stopped heating???
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Nov 21, 2007 | Dacor ECD230 Epicure Electric Double Oven
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Ovens Logo
290 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
