Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony wega hdtv
Plays for a few min screen goes black waits a min comes back on and then plays for a few min. and repetes process
  • Sony Master
  • 8,617 Answers
Sounds like a bad solder joint in the power supply or if your audio stays when you lose the video its probably in the deflection circuit either vertical or horizontal. Check the yoke connections.pins for cracked solder as well as the vertical and horizontal outputs also around the flyback.
Posted on Jan 22, 2008
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
GOES OFF AND ON
Did you replaced lamp recently in tv?
Symptom shows lamp is getting weak in result and tv requires replacement.
Lamp replacement procedure is easy and would be written in user manual.
Thanks.
Jan 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
THE SCREEN GOES BLACK AFTER A FEW MIN. THEN BACK ON....AND OFF..
Some lamps can be changed without a tech. what you need to di is consult your manual to see if it gives instructions or tells you its a service call part
If this information was useful please click
Aug 13, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Screen automatically goes black after a few minutes
Lamp in TV got weak and TV needs new lamp.
Lamp replacement procedure is written in instruction manual and buy should buy Sony original lamp from Sony Accessories Store for your Sony TV.
Apr 30, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony grand wega 55in kdf-55a20
Its most likely an intermittent lamp. The lamp door is located behind the front panel. The front panel can be removed after loosening the two thumb wheels located on either end of the TV in the rear. Observe the light coming from the area around the lamp door. If you see that the light is going out, its the lamp. You can also access the self-diagnosis menu by using the remote control. Start with the TV off. Push the "mute", then the number 5 button, and then the volume down button followed by the power button. When the picture appears, the menu will been visable. If there is a failure with the lamp, or a fan, or many other areas in the TV there will be a number value to the right of the parameter that indicates the number of times the error has occurred.
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KP-57WS510 57" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
