Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Whirlpool Refrigerator GS6SHAXML cycling on/off
I have a 5 year old GS6SHAXML. Just within the past few days, I noticed that the unit's compressor cycles on for 15 minutes then off for 15 minutes. The separation between the freezer and refrigerator side is hot to the touch. The freezer side maintains items frozen and refrigerator side seems to maintain items cool. Is this normal?
Additional notes:
The temperature is factory set at 4 / 4
I clean the condenser coils front at least once per month and replace the water filter semi annually.
The kitchen is slightly cooler.
The air flow areas between the freezer and refrigerator sides are clear.
  • amarten Jan 22, 2008
    Problem solved with a service call - the cooling fan blade was bent, probably due to an mouse. Without the fan, the compressor was heating up the internal loop on the front side of the refrigerator and running more often. Unchecked, the compressor was bound to fail.
    Once the blade was straighten, the fan and compressor returned to normal operation. The relay doesn't appear to be damaged. If it had, the compressor would trip on for a few seconds and back off.
    This model is problem prone, given that it was converted from mechanical to digital. The circuit boards that govern the lighting system tend to overheat and fail.
    Here is a tip the repairman provided me with: clean the condenser coils with bathtub foam cleaner.
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 14, 2009
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Emerson wine cooler /ER2352
I have the same problem and so do others who gave feedback on Amazon. Any ideas out there?
Posted on Oct 26, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
John Hall
  • 1218 Answers
SOURCE: Condenser fan always runs so freezer won't
Good day,
The fan motor runs when the thermostat asks it to.
If the machine is not at the proper temperature, the fan will run 24/7.
You have a cooling problem with the machine.
here are some areas to check.
1. The fan motor in the freezer compartment. It is behind the rear panel. You should be able to hear it running when you open the freezer door.
2. The defrost system has failed. Once again, open the freezer door, if you see frost built up on the rear panel, Either, the defrost timer, defrost thermostat, or main heater has failed.
3. The compressor is bad, or the start components mounted on the side of the compressor have failed.
4. Refrigerent has leaked out, or the system has an internal restriction.
The last 2 items are best left to a trained repair technician.
Posted on Dec 05, 2009
Whirlpool ultra care II quiet wash II - over the past few day has run intermittently. It stops for what appears to be no reason. Can't get it to start. I turn it off, then a few hours later when I...
Sounds like motor overheating and shutting down. Motor will have to be replaced if that's the case. Probably not feasible on a 10 year old machine
Aug 25, 2017 | Whirlpool Washing Machines
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refrigerator that is 3 years old the last few weeks it has been cycling on and off a switch or relay seems to be making the noise. Both doors are closed and seem to have a good seal....
your compressor is overloading, this is most likely due to low freon level,
you must have a service person look at the unit...
Please rate/vote this response. thanks
Dec 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer wont work after defrosted
Please keep in mind, I'm attempting to diagnose you appliance without being there and with very little info. Thanks
If the sound is a double click, then after about 2 or 5 Min's another double click. You have a bad capacitor.
If it's a low hum. It sounds to me like you have a low side leak in your freon sealed system. When you unplug the unit, the freon pressures equalize. This put higher pressure on the low side of the system than it has when it's running. If you have a low side leak, it will drain out under the higher pressure.
NOTICE
(Industury standard- 5 year warranty on all sealed systems) This means that if your unit is less than five years old and it is a sealed system problem. (Freon leak, Compressor) The factory will cover parts and labor. You should not need a receipt if it's less than 4 years old.
Sep 22, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool Side by Side- semi-translucent tape likedebris in water
Sounds like the plastic from the icemaker is chipping off the unit in the ice making process.
If your water is running clear except through the refrigerator that is my suggestions. Although normally the plastic color is blackish.
Jan 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not staying cold
put you own thermometer inside and see if the temperature is the same as the digital thermometer. the light switch shouldn't have anything to do with the temp. another thing to check is see if the condenser fan (condenser is the metal coil on the outside) is running, and that the coil is clean. if the coil is dirty or the fan is not running then either clean the coil or check for voltage at the fan. if you have voltage to the fan and it doesn't run then you need to replace the fan. if you don't have voltage to the fan then you may have a deeper problem. hope this helps
Jun 08, 2008 | Sub-Zero 650 / O Bottom Freezer...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
731 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
