Cyberhome 1500 i changed the output to pal and now it would not let me go back into setup to change it back to ntsc? help!!! buck 240 506 4905
  • 1 more comment
  • buckit Jan 26, 2008
    Could you please attach the PDF. For some reason, I am uable to view the product manual. Thanks again.
  • jansak Feb 18, 2008
    how can you download the attached manual - I need it also
  • Anonymous Mar 09, 2008
    I also changed the output to PAL and the screen jumps up and down. Now I can't get it back. I have the manual but don't know how to reset it.
    Please help. Thank you.
    Sergeant:
  • 226 Answers
Product Manual [6.39mb PDF]
Posted on Jan 21, 2008
How to convert my Philips DVP5990 to play PAL?
Press SETUP
Use the arrows to highlight Video Setup Page
Select TV Type - change it to PAL
There isn't a way to view PAL and NTSC at the same time with this player, but you can always go to the video setup page and switch between the two. Restoring the player back to its factory defaults will automatically switch it back to NTSC.
-Tha Mp3 Doctor
Feb 13, 2009 | Philips Televison & Video
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Set up video output
Pal output will only work when it is plugged into a pal tv. The only way you can restore is to use the remote to put the settings back to ntsc without using the display. That should work. If you don't have a pal tv you should never change devices to run on it, because it can damage your tv set. The scanning lines are very different between the two systems.
Aug 14, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Changing to PAL format...
i have the same issue i don't know the solution to ur original problem of B&W.. I think you might have unknowingly changed the "Video Output".. don't worry...to change it back.. do the following steps 1) Switch on dvd player with no disc 2) wait for few secs and press setup on remote 3)press -> (rt arrow) once 4) press enter 5) press down arrow twice 6) press enter 7) press up arrow once(or twice) 8) press enter hopefully this shud work..
May 05, 2007 | Cyberhome CH-DVD 300 DVD Player
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
No colour
Go to the setup menu. Change the output from NTSC to PAL. Should work.
Jan 22, 2007 | Cyberhome CH-DVD 300 DVD Player
Problem during 'setup'
I had the same problem too now my TV screen is all black and I can't do anything. can someone help please. thanks
Dec 13, 2006 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
