Question about Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore washer that is leaking bad underneath in the front making puddles of water. Im constantly keeping towels down everytime I wash a load. Could you please tell me what might be wrong? Thank you
  • 1 more comment
  • Anonymous Feb 18, 2008
  • caravan666 May 11, 2010
    Click on blue tags above, related searches, regarding water leaks, etc. You are sure to find solutions..........
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Is your washer a front loader or top loader?
  • 16 Answers
Check the front door boot first. Make sure that there are no tears in it.
Remove the back of the washer, start a fill cycle and observe outer tub sections and hoses for leaks. This is a good place to start.
Posted on Feb 23, 2009
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
How do you remove the cover of a Kenmore elite top load washer . Have a leak and need to find where it is coming from.
water coming from the bad seal on the shaft. Lift agitator, bolt underneath, loosen pull out basket. From spindle. ..seal underneath. Must take cover off first. Slide a butter knife at edges in front at seam. there's a two ,clips. in there. Usually 2 bolts up towards top on inside edge of front cover. Make sure power cord unplugged.turn basket upside down. You will see seal.
Sep 11, 2014 | Kenmore 24032\24036 Top Load Washer
I ran a load & after switching the wash i noticed a puddle of water sitting at the bottom of the washer
water puddles usually indicate a leaking water pump-check the gaskets to make sure they are sealed before replacing the pump
Sep 17, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore washer has just started this week leaking water underneath somewhere!! I noticed water down the side next to the wall & behind the washer. I then placed a few small towels behind & down...
This is either your water pump, inlet valve, or you have a hole at the top of the outer drum. Try using the small load water level, if no leaks try medium. Also try seeing if the hoses are leaking. I also have seen mice bite holes in the drain lines. I hope i have helped you. God bless!
Aug 20, 2010 | Kenmore 26442 Top Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Smells like rotten eggs
The smell of rotten eggs normally means you have some water that has been sitting arround awhile and has gone bad. You may have to unplug your machine and remove the front cover to take a look arround the inside of your machine to see if any water has leaked out and has puddled up. You may also have something caught in the drain pump's filter, which may have gone rotten from sitting around too long. This filter is easy to unscrew and gain access to once you have the front cover off. Make sure you have lots of towels or a wet vac handy when you unscrew the filter cover.
Jul 26, 2009 | Kenmore Elite 45986 Front Load Washer
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing machine
Depending on the age of the unit:
Possible minor leak at the pump.
Possible leak at the spin bearing/boot seal.
Dec 30, 2007 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
