Question about Koss KS3161 System
Isn't showing color on screen?
We own this product, and when we insert a dvd to play, it shows up black and white?...The color is their with regular tv so we know that its not the tv, and all cords are connected, is there a way to bring color back into our lives?...
I have this problem too sometimes with certain dvds. i usually scroll thru the menu settings and just switch some video options and the problem fixs itself
Posted on Feb 18, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
My dvd's play in black & white. cant get any color in pitures.
There are three types of display settings. 1 PAL, 2, NTSC and 3, Auto.
The pal and auto makes a display show color while the NTSC allow a display show in black and white but sometimes NTSC also shows color. It is possible that the display format on the movie is NTSC.
To fix this problem, play the movie that shows black and white. When the movie shows in black and white, press PAL/NTSC or P/N on the remote control and it should display in color.
Or Go to the player menu, check video or display setting, change it to Auto.
Problem should be fixed because that's where it lies....
But if it doesn't solve the problem, please let me know so that I may direct you further on what next to do.
I hope you understand the above.
Good luck.
Mar 04, 2011 | Philips Audio Players & Recorders
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
My projector only shows black and white images
probably you are facing with an NTSC signal and a PAL source or vica versa
try to check with a regular tv or with a different source
Jan 03, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Same as other poster: Player only plays black and white
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
NO color output
DAV-DZ3k is a good sony product especially ...famous for book shelf speakers,the problem is basically due to the cables used to connect video terminals or the TVcircuits is not proper with the av receiver.. Thank you Regards Sambhu Dayal
Jul 21, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
Koss KS3161 System Logo
105 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
