Question about Apple iPod MA446LL/A MP3 Player
I POD mY DAUGHTER LOST MY CONECTOR TO CONECT TO COMPUTER AND I FOUND ONE THAT FITS BUT GIVES ME THIS ERROR FIREWIRE CONNECTIONS ARE NOT SUPPORTED TO TRANSFER SONGS,CONNECT THE USB CABLE PROVIDED ... I AM NEW TO THIS AND NEED HELP WHAT DO i DO please help
    President:
  • 4,402 Answers
Are you sure the usb cable is supported buy apple?
I would buy a new one.
then try sharepod software
Posted on Jan 23, 2008
Lost conection firewire ,
Check you have the latest software or firmware drivers from their website at Focusrite.com
Check that the FireWire cable is connected properly.
Try using the supplied power cable.
Try using the other FireWire port found on the back of your Saffire product, and also try different ports (if you have more than one) on your computer.
If you have any other FireWire devices connected, try disconnecting them, as they may be restricting the FireWire bandwidth too much if connectedon the same bus.
NB: You may have more than one FireWire port on your computer. Note that they may be connected to the same bus, even though they appear to be physically seperate. This will be the case if you have a FireWire card with multiple FireWire ports on (all ports on the card will be on the same bus), and is also often the case if you have multiple ports inbuilt on you system.
Increase the FireWire buffer size on your FireWire card, found at C:/Program Files/Focusrite [Saffire product]/Driver/ASIOControlPanel.exe (where [Saffire product] is the name of your Saffire product). Its default setting is 2ms, but you may find that increasing it helps connectivity and will improve audio performance, at the cost of increasing latency.
Mar 09, 2011 | Focusrite Saffire LE FireWire Audio...
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
Hello, I connected my DCR-HC54 (minidv) to computer using USB cable (come with camcorder). latest PMB is installed on windows 7 64-bit home premium. It gives following message: Cannot find the Handycam...
This type of camera usually downloads better with a Firewire (DV) connection. Sony call this "i.Link". Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. According to a list on the Sony site, your particular model is not one that can use USB for video transfers to computer.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Sony have a help page for your camera, with tutorials and downloads, at THIS LINK
Dec 31, 2010 | Cameras
I don't have any drivers for the video camera...lost the cd years ago..how do I transfer video files to pc
I think this camera has a Firewire (DV) connection. Suitable Firewire cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
You don't say what computer you have. Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. I don't think you need camera drivers with this interface- it is also used to connect the camera to some VHS recorders and the like. The interface card will come with drivers for the card.
Nov 05, 2010 | JVC Cybercam GR-DVL820 Mini DV Digital...
How do you upload the Cassette Video into the computer?
This camera has both USB and Firewire (DV) connections. The manual seems to say that either can be used to transfer video. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
A manual for the camera can be downloaded from this page.
The manual gives some details about connecting to a computer. More information may be available from the same site.
Oct 31, 2010 | JVC Cybercam GR-D90 Mini DV Digital...
I want to connect my HP pavilion notebook dv1000 by firewire
You should be able to get a firewire card to fit you computer. A standard pc card should fit a HP. There are two separate kinds of PC cards. There are the standard and the express versions. Make sure you get the standard version, because express is mostly for Dell. You may want to go to HP and confirm this by looking at the support section for your computer. As far as what type of firewire card, get what you think you will need. There isn't much difference between different brands.
Feb 09, 2010 | HP Pavilion dv1000 Notebook
Can not connect printer to computer
go here to get your printer drivers
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX8400/Drivers-Support?supportLandingPage=true
Aug 22, 2009 | Epson Stylus CX7800 All-In-One InkJet...
I.link cable for sony handycam
Ilink is a 1394 firewire plug, install a firewire card in computer and you are set.
Jul 16, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Apple iPod MA446LL/A MP3 Player Logo
95 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
