Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips HDTV does not turn on
Hey guys, i just acquired a 60" hi def rear projection from a friend for 75 dollars because it's not working and it was taking up space in his house...
the model number is 60PP9202, and this is his description of the problem, and it currently does the same for me:
there was a power outage last week, i was watching the tv at the time. Since then, the TV doesn't turn on. The power button lights up and it clicks, but that's all. No picture, no sound, nothing. The next day i tried and it worked fine again, it worked fine for a few days. 5 days later when i turned it on all it did was click, the power button does turn on, but no picture or sound...
any of you fine folks have some direction for me? i'm proficient in working with electronics, i've worked at a bmw dealership for the past 6 years, so testing and measuring doesn't bother me as long as i know what to look for. thanks in advance for all your help!!
Josh
  • 6 more comments
  • Anonymous Jan 21, 2008
    RED LIGHT IN FRONT COMES ON NO POWER
  • JoshJohnson Jan 22, 2008
    what should my resistance/voltage values be for those? i checked the fuses last night and they both have .001 ohms of resistance, when i plug it in and turn on the front panel it'll stay on for a minute or so and turn off automatically, but i can't turn it off manually before that unless i reset the tv with the little reset button on one of the circuit boards. i also hear a hum from the coil, not sure if that helps
    when i mean turn on i only mean the red light, not the tv itself, sorry for being unclear
    Thanks! I'll measure it when I get home and let you know what I come up with
  • Leech213 Jan 23, 2008
    Sorry posted in the wrong section....
    I just ran into the same problem with my TV last night... big fluctuation in power. If you can pass on any advice you've received or if you found a fix that would be great. If I find the problem on my end I'll make sure to do the same.
    Thanks,
    Don
    [email protected]
  • JoshJohnson Jan 23, 2008
    i measured across the coil last night from underneath at the mounting posts. going across the resistance would be pretty low, less than 5 ohms. diagonally the resistance was nearly a million ohms, which is expected going through all those windings, i assume. i was also checking power at random spots on the circuit boards. into the tv i had 110v(line voltage), and at most spots that was cut in half to 55-60v. is that normal? i'm thinking if i can't get a schematic or something then i'm going to have someone come in and repair it. any last thoughts?
    Hey, just looking at the back of this info lable, I have the model number incorrect, it's: 60PP9910/17
    The chassis numer is: DPTZ410
    Thanks,
    Josh
  • JoshJohnson Jan 26, 2008
    hey guys, my problem is probably going to be different than most of yours... i had a tube leak fluid all over one of the main circuit boards, shorting it out. i called the tv place and they said that the part i needed was no longer available, so i'm pretty much out of luck. hope you guys have better luck with your tv's
  • Philips Master
  • 8,617 Answers
I would check the line coil and horizontal and low voltage regulator transistors.
Posted on Jan 22, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 22, 2008
    Your line coil is probaly shorted. I will try to locate some service info for that set to see what the actual parameters for that model are.I will get back to you on this matter.
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    Give me the Chassis number on that. I can probaly get you some schematics for you to go by when your checking the voltages.
  • Sonny Berry
    Sonny Berry Jan 26, 2008
    I will try to find out some info on hat chassis and get back to you on it.
6ya staff
SOURCE:
i this problem is in pwoer cord u change it try to on it your problem will be sloves
if the poqwer code is ok then chak your tv trnsformer
May 15, 2008 | Quasar VV-1301 13 in. Combo
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I think my color tubing is out it is sooo dark you can barely see
Not necessarily so, it may not even be the tube but a fuse that costs a few dollars. Get a proper investigation and quote
Aug 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60" hdtv projection is a lil blury what could this be?
You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Jul 14, 2009 | Philips 60PP9352 60" Rear Projection...
Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
May 31, 2009 | Philips 60PP9202 60" Rear Projection...
Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Power button lights up, but no video or sound
I have the same problem with the same tv 3 years after buying it i have a repair guy coming out on wen. to see what the problem is.
May 24, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
