Question about Brother MFC 5-in-1 Multifunction Laser Printer
Brother MFC-6800 machine error AE. No printing
  • mroski Jan 21, 2008
    Thanks
  • taraginm Nov 01, 2008
    i have same problem
    printer prints but other functions are blocked
    was told by brother that it refers to a sensor which is in the off position and must be turned on
    They couldnt tell me where teh sensor is and how to change the setting
    can you help
    the sensor is ccdhp
Same problem
called brother and they said it was the ccdhp sensor which was in off position and must be in on position
They couldnt tell me where teh sensor was located, how to access it and change it
DO you have any idea ?
Posted on Nov 01, 2008
How to cancel print job in brother's mfc 6800 printer?
open printers left click on printer and cancle aii printing jobs. if this don't work delete printer and reinstall
Aug 31, 2013 | Brother MFC 6800 All-In-One Laser Printer
My brother mfc 6800 is printing pale
In the menu of this machine there is an ecology section, make sure toner save is turnned off.
Feb 10, 2010 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Vertical lines when it prints, etc.
Vertical print problems are going to mean a drum replacement on that model. You can try to pull out the drum unit and carefully, with a lint free cloth, try spinning the drum and cleaning it off, but more than likely the coating on the drum has worn off where the vertical defect is. New part # dr-250 for that machine model..
Feb 28, 2009 | Brother MFC 6800 All-In-One Laser Printer
Machine error AE on brother MFC 6800
The error is from the scanner. It is possible the scanner lock on the underside of the scanner has shifted and not allowing the scanner to correctly return to the home position. Try Checking the scanner lock and make sure it is not in the locked position. Then turn off and on your machine while holding the menu/set button. the machine will come up either with an error or in maintenance mode. either way enter 99 and see what you get. Maintenance mode is a dangerous place to play around in. 99 exits maintenance mode. 91 resets all parameters to factory setting except stored locations like phone numbers and location information. 01 resets every thing to factory. DO NOT CHANGE ANYTHING IN MAINTENANCE MODE. CCDHP is scanner home position sensor. It will probably reset just by turning the machine off and on.
good luck.
Nov 01, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 printing all black.
more likely the scan lamp, does it shine when doing a copy of the sky?
Dec 12, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 7420 all in one Scanner not working
sorry but is the 7420 compatible with Vista? what does the box say?
Nov 08, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 5-in-1 Multifunction Laser Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
