Question about Consew 14TU Mechanical Sewing Machine
Maybe it's still a tension thing...
I just bought a used Consew 14TU 4-thread Overlock, and although the owner told me that it had been recently serviced and it was ready to go out of the box...it isn't. I've rethreaded it and adjusted tension...it might make one or two loops, but then the thread breaks or comes back through the machine. I'm lost as of now...oh, and she didn't provide instructions.
  • youngOTIS Jan 22, 2008
    I don't know about timing, other than what my reasons of deduction would tell me.
    yeah, I think I'll go that route. I'm not the most tech savvy when it comes to repairing sewing machines...but thank you for the suggestion.
  • Fasshiongrl Jan 10, 2009
    I believe I have a timing issue on my machine. I recently took my machine to a repair guy who said he could only get 3 threads to work, and told me to bring it back to finish the repair after i was done with my project i needed to finish. So i went back and he laughed in my face.I know for a fact that it is threaded correctly, neddle poisition is correct and the tension is set properly. but nothing is catching. I need help please. I am mechanically inclined. i would love you to walk me through it.
  • 397 Answers
Do you know much about timing? if not please take it to a near by dealer,,,,should only cost 40-$60 for service....if you are mechanically inclined i can try to run you through a intense process
Posted on Jan 21, 2008
What else can I try to get the Overlock tensions correct on a Burnett funlock 003? I have re-threaded checked the threading and messed with the tensions to no avail
You haven't provided symptoms of what is happening with your machine, so this is just a general guideline.
Remove all the threads from the machine. ALWAYS RAISE the presser foot when threading. Be sure to thread each thread IN THE ORDER specified--threading out of order will guarantee a problem! When threading the tensions, always give each thread an extra little tug to make sure it is seated completely (with one hand, grasp the thread below the thread tree and the other hand below the tension disk and tug--it may make a "pop" as it seats). Verify that each thread pathway is correct.
Set the tensions to the midway point. This is the standard beginning point for overlock tension adjustment, although some tweaking may be needed because every machine is different.
If the machine is still not performing correctly with some tweaking of the tensions, you may want to take it for service.
Dec 23, 2016 | Sewing Machines
I need a manual for a model 230 consew, I recently bought it from a friend, I want to learn how to thread it, and wind my bobbins, can you help me, unable to find one
You can go to the consew official website and download the PDF file for the 210 model. It's the same as the 230 r-1 (which i have). I found this information by calling the consew headquarters. You can also download a PDF with the full parts list for the 230 model specifically. This link may help http://www.consew.com/default.aspx?pageId=4
Apr 06, 2011 | Sewing Machines
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Sep 21, 2010 | Elna Sewing Machines
I just bought a Yamata BL4-434D overlock machine,
Put 4 colours of thred on the machine , set all tention knobs to 0 stitch and see what colour is not tight, adjust the colour that is not tight. Also use jersey ball point no 80/12 needles it work on all material E-Mail me wcbotha@yahoo.com From Willem SA
May 10, 2010 | Yamata BL4-434D
Tension discs/ shredding needle thread
Your knee pad raises the presser foot and in turn releases the disc tension. The mechanism for this is in the front of the machine. If you can remove a nose piece this will be a lot easier to see,
There is a pin that pushes the tension discs open and quite often this has been removed or adjusted so a to not release tension when the presser foot is raised {more likely if this was a production machine} If someone took the tension control apart to accomplish this that my guess as to question 2.
The best part about Consew is the parts are common and the whole tension assembly isn't expensive. You can find service manuals on their website (see link) http://www.consew.com/Files/112347/InstructionManuals/206RB-5.pdf
Apr 12, 2017 | Consew 206RB
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
Threading a consew 146RB-2A
I'm not sure why the person told you that because it is not true. You only have to go around the tension wheel once.
May 24, 2009 | Consew 146RB-2A
Cannot get tension balance correct
Try this. reomove thread and bobbin from machine.. Set thread tension to the middle number. Rethread machine carefully making sure the thread is thru the tension wheel. Replace bobbin making sure that thread is thru it's tensioner.
Rule of thumb. Loops on the bottom, problem is on the top. Loops on the top, problem is with the bobbin.
Apr 16, 2009 | Consew 199R-1A Sewing Machine
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Consew 14TU Mechanical Sewing Machine Logo
113 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
