Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
T.V. turns self off
Transformer blew up , I replaced transformer 40351a-1 and six mouths later set turning itself off
    Problem Solver:
  • 8 Answers
This is a common problem. May people have been noticing in the back of the television large sparks and flames are being thrown. The unit then detects overheating and turns itself off. Please report this problem to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Posted on Feb 07, 2008
HD52W59YX38 GOES BLANK
Yes, the model indicated is prone to bad solder connections (among other things) at the high voltage transformer--that would be first thing to look at.
May 02, 2012 | Televison & Video
GE D52GW12 52 in. Rear Projection HDTV-Ready
hi
i agree with you about the fire hazard and i had many feedbacks about this tv, mostly conscious about fire hazard too.
i would suggest that in light of owning a high-def tv, it would be significantly appropriate to place this in a room with airconditioning as to diminish the heat this hdtv produces.
about the issue of the hdtv turning off, if you suspect the transformer and other parts to be the reason for the tv to malfunction, why not bring it to a certified service center which handles GE hdtv. i would say that it may be a pain but as to think of the outcome, it may be worth it.
hope this helps.
Jan 21, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Fuse keeps blowing in hotpoint microwave
The magnetron is the other issue, high voltage diode will sometimes crack causing a high level short, the capacitor developes a dead short across the 2 points, the power transformer almost never fails, "very rare"
Apr 08, 2012 | Hotpoint RVM1635 Microwave Oven
I replaced the inducer motor and the relay switch
If you sparked a wire connector at all, there's a good chance you blew the fuse for the 24 VAC transformer. There may be a fuse holder for the transformer on the box that has all the control and T/stat wires. If you can't find one then it's internal to the transformer and you'll have to replace the transformer.
Feb 14, 2018 | Heating & Cooling
I tried changing the thermostat (unsuccessfully) and may have blown a transformer. My AC unit will not turn on. Is this an inexpensive repair?
If you did not turn off power and or have a hot wire touching a common wire you blew the transformer. There is a possibility your air handler has a 3 amp fuse on a control board. Check it first. If it is OK,replace the transformer.
Sep 24, 2009 | Ruud UAKA030 Air Conditioner
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
When I turned on my viking 980, the power went on for a moment and then went completely dead. Checked that outlet has power, all connections are made securely.
More than likely it blew the fuse in the transformer, although it is fairly easy to replace this fuse it is important to find out why it blew. The transformer is under the machine and held in place by 4 screws. Take this out and ease the transformer out, it will still be hooked to the connecting wires just gently disconected them. Once you open the transformer you will see a small fuse, you can take it to radio shack and get an EXACT replacement.
I have fixed 100s of these of the last 25 years
Jun 28, 2009 | Husqvarna Viking 1
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Set turns it self off
I have A tech coming out tomorrow. It sounds and smells like the power supply board. Is there parts still available?
Jan 15, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Power transformer
How do I know if the transformer went on my tv I saw a rd light & then it smelled like wire burning & the tv shut off & won't go back on. Haier 40 inch hd
Oct 22, 2007 | Haier HL37 37 in. LCD Television
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
