Question about GE WSXH208A Front Load Washer
Front load washer model #WSSH300G0WW
I accidently pushed the delay button, instead of start. Now I can't get a normal wash. How do I turn off delay and push start? I am desperate in Atlanta. Please help asap..it's not my washer, I'm baby sitting. I cannot get behind the washer to pull the plug. Thanks
Push the button again...... its a toggle button the delay is either on or off.
Posted on Mar 17, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
F6 e2 on front load whirlpool
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Mar 12, 2013 | Washing Machines
Accidently pushed delay start, now annot wash
Hi sallysue5928 - How long was the delay start set to? Typically the delay time selected will be displayed as 30, 60, or 90 minutes or 2 through 14 hours. However, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful then unfortunately you will have to wait till the time of the delay start cycle that was selected.
Feb 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
User issue
push the delay wash button until the light goes off
May 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
GE WSXH208A Front Load Washer Logo
487 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
