Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Leaking from the water Chamber
My Krups Coffee 867 Maker is leaking when I pour water into the water Chamber. I suspect it is a seal, but I don't know how to take it apart to replace it and where to get the seals
  • Anonymous Mar 11, 2008
    My mom has the same problem with her Krups coffee maker. When she pours water into the chamber, it leaks out of the bottom of the coffee maker. It's isn't a Krups Caffee Bistro. It's a simple Krups coffee maker with no extras on it, just on/off button. If the problem is a seal, where can I purchase them and is it easy to install it?
    Habit-Forming:
  • 83 Answers
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Posted on Apr 16, 2008
Leaking Krups xp 7200 Coffee Maker
It is a Torx T15 screw. Common leak point on those is the barista seal at the bottom of the brewing chamber but that is by no means the only leak point. You need to get the covers off with your new Torx driver and see where the leak is
Apr 01, 2013 | Krups XP Coffee Makers & Espresso Machines
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
I have the krups espresso and caffe machine and i have no idea how to MAKE espresso (it's NOT the one below)...
turn on your krups espreeso to warmup the water, put one spoon of coffee in the handle, lock the handle and turn on the pressure button, and the coffee leaks in your cup, that's all
Apr 27, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Icky stuff
I would suggest to disassemble the machine and clean individual parts, chunky orange is rust, which is not normal in the coffee machine tubing.
Jan 30, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffeeheater
Try like I did, which is to fix the leaks with alluminum welding or have it tig welded by a welding shop, use a very powerful magnifiying lens to inspect for cracks also, Clean the piping and run a ton of water through it before you have coffee !
Oct 29, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups xp 4020 leaking
My Krups leaks like a sieve and I found parts (seals) available at  smallappliance.com
Sep 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Coffee maker side will not work.
check inside for broken or burnt connectors going to the heater element. these are normally slide in spade connectors.
Sep 10, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Open Questions:
See all Krups Caffe Bistro 867 Espresso & Coffee Maker Questions
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
556 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
