Philips freevents notebook non starter
I have the above notebook that will not turn on 3 weeks after the warrantee ran out!. The battery says it's charging but the machine lies as dead as a Dodo on pressing 'on'. ... no sound of things working ... no lights flickering except the charging light.
I have noticed it ran very hot ... do you think the power unit is caput.? If so where can I get another. I checked the on/off switch and that seems fine but no power getting through except to the battery...
Any suggestions?
Thanks in anticipation
Jon B-Shead
  • djdebbie Feb 21, 2008
    I have exactly the same problem. It was working fine then an hour later went to switch on and nothing. Battery still fully charged and charges fine but no power to PC. There should be a reset button but can't find it.
  • rubyB Oct 05, 2008
    I have the same problem. Battery charged and connection ok but will not switch on. Book says reset hole but no sign of it. RubyB
  • 1,067 Answers
Ya bad mobo no greese left on cpu take aprt redo greese thermal paste on cpu ok blow it all out dust getting labtop cooling bad never set these on beds big no no on any labtop must be on hard serfice ok cheak heat sinks paste proably none left worn out gets to hot fails killled power chips in it sell it for parts on ebay
Posted on Jan 21, 2008
How do you open a Philips Freevent LS1400
Dec 16, 2013 | Computers & Internet
Remove cd/dvd drive on philips freevents laptop
use a pin on the hole in front of CDROM to open the CD ROM
May 14, 2012 | Philips Brand 12.1 WXGA Glossy Laptop...
Truck will start for two weeks then wont. put a new starter in it ran for two weeks then wont start again. old starter tested bad so replaced it. put a new one in and coil pack ran for few weeks then won't...
check alternator output at the alt and at battery also put a test light on the starter solenoid at the little wire on solenoid see if it lights up when turn key ? possible positive or negative cables have good ohm checks but not carrying enough current ?
Jun 01, 2010 | 1998 Chevrolet S-10 Pickup
I recently changed the starter motor and it ran fine for 2 weeks. i went out of town for 3 days and now the car wont start. theres no click at all. the battery is new as well. i think its something in the...
Starter turns the engine so the ignition system can fire the engine. If it will not turn, go back over starter circuit.
Starter solenoid is part of that circuit. Don't assume battery is good without testing. It must have a minimum of 12volts and should withstand a 200amp load for 15seconds and return back to 12v immediately. During loading, volts should not drop below 9.5volts.
Oct 05, 2009 | 1999 Dodge Durango
Recovery disk for Philips Freevents and system running slow
Readthis thread before you attempt anything.
Aug 02, 2009 | Computers & Internet
Over heating laptop - Philips Freevents X51
the overheating of your laptop occurs when there is dust surrounded in the fan. try to open your laptop fan and clean the dust this will surely reduce your over heating problem, thank you,, plz do rate me,,,
Jun 29, 2009 | Fujitsu Siemens Lifebook N5010 Notebook
Philips Freevents X50 charging problems
well my friend I hate to say this but the problem is in the motherboard, and the motherboard should be replaced.
Jun 27, 2009 | Computers & Internet
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Start up problem
Uninstall the software or hardware which you have recently install
Jun 19, 2008 | Computers & Internet
Philips freeVents X50 Model f12dt
here is a link to a few pages full of the battery you need:
philips freevent x50 model f12dt battery
hope that helps
also call best buy they can surely assist you or special order one for you, they also have many references of other places you can go.
May 15, 2008 | Computers & Internet
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
