Question about Avaya 700340193 Corded Phone
Lucent phone system:
Power outage caused system to go dead need to reset system. Model 103E19
If this is a partner acs, AND it has a backup card:
From ext 10 or 11:
Press feature 00
left intercom
left intercom
#125
it should show a backup file. if none, the entire system will need to be completely reprogrammed
if there is a file there, you need to hit the enter button. the enter button is the 3rd button down farthest to the right.
the system will power down and come back up. time and date will need to be redone though.
Posted on Jan 22, 2008
Lucent Partner 18D phone loses speed dial program after power outage. Is there a backup battery that needs to be replaced?
At the phone: No
This phone is attached to a Partner panel somewhere in your building most likely. At that panel there is either a slot card or a carrier box with several cards in it. One of them is the processor card, on that card at the front should be an area at the bottom w/ a "+" plus sign on it, move the black (usually that color) slide and there will be a carrier for 2 AA batteries (or AAA), replace those and the info should be saved. Alternatively some of these system have a PCMCIA memory card that you can use to back them up and then restore them if something goes wrong later. If you find the main phone on your system (usually 34 button) it may even tell you the batteries need replaced. When we install we also highly recommend hooking the main phone system to an APC backup, even something as small as a 500-600 series just to both protect your investment and in small outages eliminate the worry of this problem.
Hope this helps you.
Apr 28, 2010 | Lucent PARTNER18 Corded Phone
I need to reset our Redial function, it was lost after a power outage.
To program a redial button press feature 00. press the button you want to make a redial button, and enter feature 05. Press feature 00 to exit porgramming.
Apr 22, 2010 | Lucent PARTNER18 Corded Phone
Lucent Partner 18D cant fully reboot itself
That one doesn't sound too good.
You could perform a reset through programming which should clear the scratch pad.
Thats done by entering programming on either ext. 10 or 11
Press feature 00 then the left hand intercom twice.
Next enter # 728, the display should say reset save all then reboot the system.If the problem is still there, then the processor is malfunctioning and will need to be replaced.
Dec 04, 2009 | Avaya Corded Phone avaparp18d
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Power outage and lost features
The Privacy is part of FP1. You need to pick a button with a light, put the T/P switch in P, touch the button, dial *72, and put the switch back in the center position.
If that doesn't work, try Auto Ans Intercom or Do Not Disturb under the same button (*70,*71). If you can't get any of the features to work, I'm guessing that the FP cartridge needs to be replaced or power down the system and remove and insert the cartridge again.
Carl
or
Apr 07, 2009 | AT&T ATT / Avaya / Lucent Merlin 820...
Static in phones
Static on Partner systems is not too uncommon and more likely as the system ages. These systems use relays (electric switches) to connect to outside lines and extensions. The static is usually from a faulty relay, but sadly these are not really repairable by end users. A power outage is sometimes associated with spikes - short high voltage conditions that occur as the power comes back on. Any vulnerable component may fail at that time. The solution is to replace the bad circuit pack. These are available used - just use your search engine. Prevention can be as easy as installing a good surge and spike protector power strip between the system and the outlet.
Dec 31, 2007 | Avaya Lucent Partner 616 Phone
Power outage lost fetaures
Contact these guys (sorry they dont still have a manual online); http://www.alcatel-lucent.com/wps/portal/ContactUs Hopefully they can help you out :)
Jun 27, 2007 | Lucent 1872 Corded Phone
Avaya 700340193 Corded Phone Logo
353 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
