Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
RE HOT WATER
I wonder to wich pipe needs conect hot water because the bouth is blue
  • 139 Answers
Cehck where the pipe connect to the machine and you will see H on one and C on another
Connect the pipe to h and then connect it to the hot water and vice a versa,,,
hope this helps any problems dont hesitate to ask...
the clour of a pipe does not affect anything
Posted on Jan 21, 2008
Is the indecit wm12x washng amchne a hot or cold water fill?
Hi from retired Englishman in SW France @ 13:45 Tues afternoon.
You can easily check by looking at the back where the water pipe or pipes need to be connected. If there is only one inlet then it is a cold fill and the machine will heat the water up itself.
If there are two inlets the hot is normally marked RED and the cold BLUE.
When the hot water is not hot enough for the particular wash, the machine will heat it in the same way as it would heat just cold water. If, however, the hot water is too hot, it will mix in some cold!
Cheers,
John C
Feb 08, 2011 | Miele Washing Machines
We are installing an American Standard Water heater and are wondering do we need to remove the pink plastic plug/gramet in the hot water side and the blue plastic plug/grammet from the cold water intake...
Yes, if these plastic parts cover pipe thread or would stop the flow of water.
If the plastic parts simply sit around the pipe like a collar, then they do not have to be removed.
Red marks for Hot pipe
Blue for cold water inlet.
If your hot and cold are reversed, then water heater will not function.
In ordinary installation, cold water line has the shut off valve.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Jan 09, 2011 | American Standard Water Heaters
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
I am afraid that you have burned the heating element out or an inline fuse is burned out
May 15, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Kenmore washer doesn't spin
the conection b/w the motor and the gear got damage you can get the part online and do it yourself.
you just need to take the pump out and the motor wich bouth connect by clips .
hop it help you
Jan 12, 2010 | Washing Machines
Installed gld4950p00cs ge and the hot water line
titen conections, maybe use teflon or pipe dope on threaded conections re titen
Jun 13, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Water is not hot enough
What a great energy saver response....run water through another tap in the house in order to fill the pipes with hot water! I have the same problem; cannot even get WARM water in my tub. I have 2 solutions: #1, on my incoming water pipes are regular faucet handles which I am going to attach a hose on the hot side that will reach into the washer and manually mix the temperature. #2, purchase an old refurb washer at a used appliance store that HAS a hot-water setting and hope they will take the "wonderful, new energy saver" as a trade. There are just some times you really need HOT water. I can't imagine washing diapers in cold, although I haven't had to do that in many years. Energy saving factory settings: capital "B", capital "S"!!!
Mar 30, 2009 | Washing Machines
Washing machine
This is a Hot and Cold fill m/c.
You obviously have the hot water supply connected to the cold in let valve..
at the rear they are marked H and C .
Make sure the cold water is connected to C,and the hot to H.
Plz rate my solution. Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Home
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
