Question about Dell 1600n All-In-One Laser Printer
Dell Laser multifunction fax failure
our fax will no longer send and our phone line that was plugged into the 1600n is dead. We don't believe it is the phone cord as it has neither been moved nor touched. Any suggestions?
    Scholar:
  • 105 Answers
This is a question that your IT manager or phone technician should be addressing/troubleshooting. If phone line is not working, chances are that the problem therein resides and not with your printer. If you plug in a regular, non-cordless phone, test for dial tone. If none is present, suspect line damage somewhere. Try plugging in the printer to a different data/phone line if available.
Posted on Mar 27, 2008
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Copy Setup: Restores all of the Copy Setup options to the factory default.
Fax Setup: Restores all of the Fax Setup options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
Phone Book: Clears the speed dial or group dial numbers stored in the memory.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Jun 12, 2014 | Dell 1600n All-In-One Laser Printer
Can send fax but cannot receive
Check if auto-answer is enabled and how many rings does it take to pickup the call. Do you have more phones in that same line?!
Do they work fine?!
Feb 04, 2010 | Dell 1600n All-In-One Laser Printer
How to change the date in a dell 1600n 3 in 1 printer
Have you tried to connect to the printer with a web browser? There should be a date setting in the web interface.
Jan 15, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n only receives 1 page of fax.
turn off ECM (error correction).
then if problem persists, slow down the fax speed to 9600 bps.
this problem always occurs with a digital or VOIP line.
Jan 14, 2009 | Dell 1600n All-In-One Laser Printer
1600n printer. bought to replace exact printer. I can not get it to send fax. My receiving is fine..just can't send. Anyone with a suggestion? Thanks.
hellow sir; when you connect the phone cable from wall jack to the machine , make sure you have plug in "line" jack,you must plug in wrong jack.
Dec 29, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1815dn
hmmm..would that error be SMTP, by chance?
Aug 14, 2008 | Dell 1600n All-In-One Laser Printer
My dell 1600n will not print recieved faxes
ok..one at a time..if you want, repost these separately to me, if they are still current.
Jun 05, 2008 | Dell 1600n All-In-One Laser Printer
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
79 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
