Question about Hotpoint RGB524 Gas Kitchen Range
Hotpoint Gas Range (model: RGB524PN1AD)
The oven knob turns (round and round) and won't shut off gas. What could this be. Some guy told me it was the thermostat. The cost of a new thermostat is crazy! Any ideas. Everything else works fine.
Gregg
  • FrankMorelli Feb 07, 2008
    The gas oven turns on by itself sporadically
  • amwdmw Dec 04, 2008
    Same problem. Have been trying to line up the knob to get it shut off....but haven't gotten it yet. Help!
My apt smells like gas in the a.m. and the oven doesn't work. Same Brand
Posted on Apr 21, 2012
  • 125 Answers
The knob could be stripped or cracked. Try to shut it off with a pliers, careful not to damage the shaft. If thet works get a new knob.
Posted on Jan 21, 2008
    President:
  • 1,314 Answers
Pull the knob off note the position of the brass gas valve turn the knob 90 degrees see if the position of the brass piece changed the same as knob if not inspect the knob see if its cracked also look on the shaft see if there is a small d shaped metal piece on it if there is it goes up inside the knob let me know what you find will advise from there
Hotpoint NG oven/range RGB524PEA5WH, electric start. Oven will not light but range will. Any suggestions please.
when you wish to light oven what is you normal procedure . push in on knob and turn the gas valve may be broken .
Mar 05, 2015 | Hotpoint Kitchen Ranges
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Hotpoint gas stove with electric ignition, model # RGB745GEV2WH -- oven will not come on -- I played with the knobs and got it to come on once tonight but can not duplicate that. Oven will simply not turn...
That's you ignitor. They get weak. If it has a glow that is dim orange that is a sign. Another sign of a weak glowbar is you can kick the oven and make her lite off. themobilian_467.jpg
Dec 17, 2010 | Hotpoint RGB535 Gas Kitchen Range
I have an gas stove Hotpoint model RGB524PEA2WH and Im trying to use my oven but doesnt work.I can see the ignator working, but the gas does not come out. I check the parts and seems to be fine. What can I...
What do you mean "checked the parts?" If you are not a qualified tech DO NOT TOUCH ANYTHING! Check to see if there is a separate knob by the thermostat that turns on the gas.
Dec 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
How to turn on oven?
mam please check the gas line is open and if the unit is idle for long time the gas line may choked so first you check the gas line.
Sep 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven/range
Is it a gas or electric if it is gas take knob off usally in front where it says 150 degrees and up and if you look down the shaft you will see a little screw turn it counter clockwise to turn oven down if it is electric take knob off where it says 150 /250/etc... and look behind the knob in your hand it has 2 screws to adjust the oven temp.
Aug 25, 2008 | Kitchen Ranges
Oven ignites by itself
Any chance that the plastic knob was cracked and not really turning the shaft of the thermostat?
What did you find the problem. I know this response is 2 months after the last post above.
Eddie
Jun 08, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB524 Gas Kitchen Range Logo
274 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
