Question about Pioneer PRO-1009W 57" Rear Projection Television
Pioneer Pro 1009W Blue Convergence
Blue convergence won't align. Moves up and down but not left or right.
  • 1 more comment
  • Groaty Jan 21, 2008
    You seem to think the problem is in the power control board, not the convergence module. Before I try your solution I want to make sure you want me working on the power board. For some reason I want to think the problem is in the convergence module.
  • Groaty Jan 22, 2008
    The response received indicates I'm trying to get rid of a "flicker". There is no flicker, just no adjustment of the blue convergence. All other function of the TV work great. The reply also indicates the board I'm to remove is a vertical board on the right rear. My power board is horizontal in the right rear.
    My problem is the blue convergence will not move left or right when I try to use the remote to align the convergence. The red convergence works fine and is aligned. But the blue convergence is off by 1-2" to the right of the cross and will not move when I use the remote. It will move up and down.
    If two or more of you pros agree the problem is in the power control board, I'll remove it and resolder. But it seems to a novice person, such as I, that the problem is in the convergence circuity, not the power.
    No servo or motor. Also, the remote accesses the convergence menu, from there you must adjust each viewing mode of the TV. As I stated earlier, everything and I mean everything works just great except the left right adjustment of the blue convergence.
  • 64 Answers
I know this seems simple but have you tryed using the controls on the front of the TV to control the alignment? Also there has to be some sort of servo or motor that controls the alignment if each color. Its possible that it might be that and not the controller.. just taking a shot in the dark.. good luck.
Posted on Jan 22, 2008
  • 1,067 Answers
Turn off main power switch, wait a few minutes and UNPLUG SET. Wait several minutes to completely drain high voltages. The power supply board is large vertical board in the back on the right side, AC cord goes to it.
There is an RF coil near the connectors at upper left, be careful not to squash it with your thumb when disconnecting wire harnesses. (oops....) After removing all those screws, handle board with two hands, as it flexes quite easily. For some reason the actual PC board is very thin, in relation to the weight of the components. Try not to flex it too much, or it may cause more broken solder points. Rest the board on blocks of wood when working on it.
Use an 8x magnifying loupe (available at photographic supply houses) or glass to inspect solder joints, as you will not be able to see breaks with the naked eye or reading glasses. A cold solder joint can be described as being dull gray and/or pebbly in appearance, sometimes accompanied with a "fracture ring" around it. Found quite a few on my board. Gently wiggle the component on the other side to see if the actual joint wiggles as well. if it does, re-solder it.
As I suspected, there were broken solder joints on connector E3 (12+ supply and a GND) and the joints for and around IC204 and IC202 looked "cold" with possible ring fractures. It's amazing how little solder was used on these joints, especially the connectors. (shame on Pioneer's QC...)
This section assumes that you have had previous soldering experience, such as an electronics hobby kit, repairing something on a circuit board, etc. Again, if you are not comfortable doing this, have someone who knows how do it for you.
Work on the board in a well-lit area, such as a workshop. (a dinette set with chandelier lighting just doesn't work!) A desk lamp for additional lighting helps. Prop the board up to prevent flexing. I suggest using a magnifying headset such as an OptiVisor (available online or dedicated tool supply shops) to see what you're doing while soldering, some of these joints are quite small.
Use an AC-powered 30-40 watt soldering iron with a fine tip. Cordless units, such as a Wahl, are okay, but pressing the "on" button gets tedious after awhile, and because of the wait time for heat-up, may not be consistent. Do not use a high-wattage soldering gun, the trick is to solder the joints, not vaporize them... I used a Weller soldering station set on "4" with good results. The iron must be hot, meaning that the solder liquifies instantaneously on contact. Also used fine 60/40 rosin core solder, for PC work. Clean the tip on the iron frequently, using a wet sponge.
It's your choice if you decide to re-solder all the joints on the board, I only did the questionable ones. On the connector pins, however, I desoldered these with a vacumn pump and re-soldered them. I did ALL the connector pins just to be safe. Re-flowing solder on the other components should be sufficient, just do it quickly to prevent over-heating of the actual component. You can also use clip-on heat sinks on the component leads, if you can reach them. (the board heat sinks sometimes get in the way)
When you're finished, inspect your work - look for free-floating solder "blurbs", and make sure you didn't solder two joints together accidentally. Re-install the board, and hopefully, the flicker is gone for good.
Posted on Jan 21, 2008
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Hitachi 50FX20B 50 inch: Blue Convergence --will not adjust
You need to change convergence amplifiers. Should be no problem for a professional
Apr 08, 2009 | Hitachi 50FX20B 50" Rear Projection...
Colors are skewed on Pioneer Pro-520HD
you can replace your the convergence chips on the convergence board. The board is to identify because it has a large heat sink. The convergence chips normally starts with STK... After you find the chip, you can buy online (ebay has a lot of listing) and costs around $10. If you know how to solder, it is very easy to do. I just replace the convergence chips on myPRO-610HD and it works perfectly.
Feb 20, 2009 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer Pro 1009W
Replace conv ICs. This usually does it.
Mr Bob
Jan 11, 2008 | Pioneer PRO-1009W 57" Rear Projection...
Red shadows on images
Sony Convergence
Nov 18, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Tuning Promblem
You have the typical convergence problem my friend. This is going to involve getting a service manual, locating the two convergence IC's. Then you will need to unsolder then from the printed circuit board. Then you will need to put heat sink compound on the new IC's before you replace them, then most likely, have to do some touch up convergence alignment through the service menu. If you have no solid state repair experience working on printed circuit boards, play it safe and call in a pro to assist you in this repair. Good Luck
Jun 05, 2007 | Hitachi 50DX01B 50" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
