Question about Disney DTD1363-CAR 13" TV/DVD
TV getting tires off to open TV
Kid pulled the cord out of tv , how do you get tires off to get to screws
OK THANKs how do you get those off ! tried
Posted on Jan 31, 2008
Screws hidden under wheel nuts
How do you replace the lamp in the tv
Use these steps to do
  • 1
    Turn off the TV, and unplug it. Make sure to disconnect it from the outlet completely.
  • 2
    Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb.
  • 3
    Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver.
  • 4
    Gently remove the bulb. Pull the bulb out of the compartment, usually by grasping a handle and then pulling out and slightly down.
  • 5
    Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the television. Slide the new one into place.
  • 6
    Tighten the screws. Do not overtighten them; they should be finger-tight only.
  • 7
    Close the door. Make sure it is closed completely or the TV will not operate.
    X2 Performance Chip
  • Jun 19, 2012 | Televison & Video
    Tip
    How to Replace the Bulb in a Projection TV
    Instructions Things You'll Need:
    • Rubber gloves
    • Replacement bulb
    1. Step 1 Turn off the TV, and unplug it. Make sure to disconnect it from the outlet completely.
    2. Step 2 Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb.
    3. Step 3 Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver.
    4. Step 4 Gently remove the bulb. Pull the bulb out of the compartment, usually by grasping a handle and then pulling out and slightly down.
    5. Step 5 Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the television. Slide the new one into place.
    6. Step 6 Tighten the screws. Do not over tighten them; they should be finger-tight only.
    7. Step 7 Close the door. Make sure it is closed completely or the TV will not operate.
    on Mar 24, 2010 | Televison & Video
    WANT TO REPLACE THE BACKLIGHT ON MY SHARP 55R wp4H
    Turn off the TV by pressing the power button. Go to the rear of the TV and pull the power plug from the electrical outlet. Wait 10 minutes for the power to drain from the LCD TV's capacitors before going to the next step because TV store a lot of current which can cause electric shock.
    Go to the back of the TV and locate the lamp tube replacement panel in the lower right corner. Pull the maintenance cover off by hand first. Then unscrew the Phillips-head screw that secures the smaller tube door panel down. Pull the door panel off and unscrew the two retaining screws that hold the lamp tube in place. Pull the lamp out by hand and then insert the new tube. Screw the retaining screws onto either side to hold the lamp steady.
    Re-screw the tube door panel back into place and then slide the maintenance cover over that. Turn the TV around. Plug the power cord into the electrical outlet and turn on the TV and that would be all.
    Regards.
    Apr 26, 2011 | Televison & Video
    I triped over the cable cord. Cable cord end that protrudes fron TV was broken off. need to replace it so I can get cable reception.Please Help .Other wise the T V was showing great.
    I'm sorry to tell you this ... when this happened with the TV at work (a camp;ing resort), we found the "F" connection was mounted to a printed circuit board attached to the 'motherboard' of the TV. The board was more than $100.00. We bought a new board and the new kid got to it before I could and he mixed up the wires. After the technician was done with it, the bill was another $250.00.
    What I can recommend to you to prevent future damage is dont connect the cable to the TV -- get a short piece of cable and fasten your TV to a "F" fitting stand-off which would be firmly mounted to non strategic part of your TV. Then connect the cable to the stand off. Next time it is pulled on, it will pull the end off your cable (fix for a couple bucks) and not tear the guts out of your TV.
    The parts are probably available to you. Make sure you have the right parts in your hand before you do anything ... and then take lots of pictures and notes as you remove the old and insert the new.
    I hope this helps you ...
    a
    Oct 08, 2009 | Televison & Video
    Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
    A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
    1. Unplug the power cable to the TV.
    2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
    3. Remove the lamp door completely from the TV.
    4. Remove the two retaining screws on the lamp case.
    5. Lift up the fixed wire handle of the lamp.
    6. Pull out the handle slowly and remove the lamp case.
    7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
    8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
      step 3.
    9. Replace the lamp cover and tighten the cover screws.
    10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
      seconds for full picture brightness), the TV should operate normally.
    If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
    door are installed correctly:
    • The lamp indicator flashes green.
    • No picture
    • Dark picture
    • TV will not turn on
    If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
    Source
    Aug 31, 2009 | Toshiba 44NHM84 44" TV
    Power switch turns on and off
    that would work if you want a costly bill. Try this before dishing out cash, the problem is the switch that tells the board to turn on and of is bad and a cheep quick fix is to open the back of your TV(#15) (unplugged of course)and remove the hex(#10) screws to the mother board look under TV tube and you will see the switch board,remove both hex screws(#10) and pull the switch board out,follow black cord to mother board and pull cord out of its port. know find the word KEY also #2 on the switch board, should be the red wire. cut this wire and be sure there isn't any bare wire showing at your cut, a piece of black tape will help this. reinstall the switch board and mother board and back of TV . you should be all good to go
    Jun 26, 2009 | Televison & Video
    Yellow input/output cable broken off in TV
    you can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
    May 12, 2009 | JVC Televison & Video
    Need to disassemble the unit.
    Disney Cars TV\DVD Combo:
    The lug nuts on the tires are plastics caps that hid three screws I was looking for to remove the tires. Once I removed the tires there were 2 screws on each side that I needed to undo and the chassis was gently nursed off.
    Upon open the chassis I noticed that the plug wire had a harness on the "business end, it it was disconnected from the circuit board where it "plugged in". Once I plugged it in and then teste to see if the set would turn back on everything was working fine.
    Dec 21, 2008 | Televison & Video
    HOW TO OPEN TV
    try taking the fake "lug nuts" off the tires with a set ff channel locks. Just pry them off easy. There will be 2 or 3 screws holding the wheels on. Remove the wheels and take out the visible screws there. Then remove the 4 easy to see silver screws underneath.
    Hope this helps
    Apr 05, 2008 | Disney DTD1363-CAR 13" TV/DVD
    Disney DTD1363-CAR 13" TV/DVD Logo
    57 people viewed this question
    Top Disney Televison & Video Experts
    Jaime Hernandez
    Chris Goulet
    Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
