Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Frigidaire dishwasher My dishwasher (new last June) has started arc'ing inside the unit. It did this three times last weekend and I unplugged. Any ideas?
  • 1 more comment
  • REQueen Jan 21, 2008
    It is arc'ing right below the silverware basket on the right side - very close (if not right at) the area where the heating element plugs in.
  • REQueen Jan 24, 2008
    I haven't had a chance to open the unit and find out but a loose wire does make a lot of sense. Thank you so much for your help!
  • robert samples May 11, 2010
    where in side the unit is it arching top bottom etc
    President:
  • 1,314 Answers
Remove the silver cover on the right side and see if there is a loose wire or a bare wire touching the box if not then check the connectors for a loose connection as they will arch also
Posted on Jan 21, 2008
  • robert samples Jan 24, 2008
    well let me know im here to fix things thats the best place to start looking
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
Apr 19, 2014 | Microwave Ovens
START BUTTON WON'T WORK
Unplug it for ten or so minutes and that might reset it..
Dec 12, 2013 | Frigidaire FPHD2491KF Dishwasher
Frigidaire fdb1050rec 154427301 Have had this
Good Morning Kate, thank you for your inquiry!
Often when a dishwasher leaks, it is because the unit could possibly be unlevel. If not, water can be leaking over the front lower baffle in the door. Try looking along the cabinet and see if the unit is even with the cabinet. Measure the correct amount of detergent as found in the Owner's Guide. It is recommended to use one teaspoon for every three grains of harness. If regular dishwasher detergent (for sink use) is used in a dishwasher it can also cause excessive sudsing. Lastly, the dishwasher could possibly have a loose water vale or a crack in the tub. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 05, 2013 | Frigidaire PLD4555RFC Dishwasher
What is the significance of this bank holiday was it to do with the Queen mother
The spring bank holiday started as the Monday after Pentecost. This is known as Whitsun or Whit Monday in the United Kingdom. The Banking and Financial Dealings Act 1971, moved this bank holiday to the last Monday in May, following a trail period of this arrangement from 1965 to 1970.
In 2002 this bank holiday was moved to June 4 to follow an extra bank holiday on June 3. This gave people a four-day weekend to celebrate the Golden Jubilee of Queen Elizabeth II. This marked the 50th year of her accession to the throne of the United Kingdom. The spring bank holiday will also be moved to June 4 in 2012 to form a long weekend together with the Queen's Diamond Jubilee bank holiday.
May 27, 2013 | Computers & Internet
Frigidaire ffbd2407ls0a dishwasher will not drain hose not kinked. Also checked drain area inside unit. Possible pump is out does not sound like it's trying to pump water out.
Hello Seth Langston - When was the last time you clean the filter? Is the unit making a grinding noise? If so, I strongly suggest contacting a professional to accurately diagnose the drain motor/pump.
Sep 30, 2012 | Dishwashers
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
All lights are flashing but he dish washer wont start.. was working fine before I went out of town this last weekend..
It might be that you had a power surge try unplugging the unit for a few minutes or trip the breaker.
good luck,
rsmith972278
Oct 12, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
73 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
