Question about Sharp AR-160 Copier
TROUBLE SHOOTING SHARP COPIER CODE F 5
HELP WITH TROUBLE CODE F 5
  • hafeezbader Jan 07, 2009
    SHARP AR-M205 GIVEING CODE H 200
    Problem Solver:
  • 4 Answers
I have problem in Sharp AR 200,and i dont know haw to fix,error code F5
Posted on Dec 10, 2008
    President:
  • 4,402 Answers
SHARP AR160 F5-02 Exposure lamp blown
Posted on Jan 21, 2008
I have sharp lcd tv . when i turn on the tv, i get sound with out the picture. what might be the problem?
Posted on Jan 20, 2009
How to fix E7 error in sharp copier.
Get a manual by typing on your search engine " Sharp model number of your printer user manual ", use trouble shooting section and it should help you.
Apr 30, 2016 | Sharp Office Equipment & Supplies
My sharp 5618 copier is showing F2 code, how can i clean it
Get user manual on your search engine by entering "sharp 5618 user manual" and check trouble shooting section.
Apr 28, 2016 | Sharp Office Equipment & Supplies
My Sharp AR 5618 copier shows E7 sub 11. whats the problem
Get the user manual, enter "sharp ar5618 user manual" and it will show sites to get manual. Check the trouble shooting section.
F9-88 code on arm317
F9-88 = Print PCB to Main MFP Board Comm Timeout
You can clear this by turning your copier off and then on. Try turning it back on with the network cable unplugged, run your machine, then plug the network cable back in. If the error code comes back, its: 1) bad network cable 2) ungrounded electrical plug for copier or router 3) noise on network line 4) copier needs firmware update 5) replace the print board
Apr 02, 2014 | Sharp AR-M317 Black and White Copier
L4 ERROR ON SHARP AR-5316E
Hi:An L4 error means the main drive motor is locking up. This would involve a step by step trouble shooting process by a tech to find which component in the copier might be causing the main motor to stall.
Andrew
Jul 09, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp sf 7900 copier, after paper jammed and removed the trouble shooting code light H-4 keeps flashing
HELLO
try to remove or unplug the power from the outlet and also same at the back of the printer and wait for 5 minutes and put it back on
just leave comments
thank you
Mar 15, 2011 | Sharp Office Equipment & Supplies
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Sep 27, 2009 | Sharp AR-M208N Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-160 Copier Logo
953 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
