Question about Sony KV-27V42 27" TV
Channel Reception When i first turn the TV on i get snow and no sound, I can put a dvd in an put the TV in video mode an i have a great picture and sound. if i come back an turn the TV on hours later the picture will be there an i can use the auto tune to fine the channels and its fine, the next day turn the TV on snow, and it cant find the stations,once it gets the reception it tunes in the station fine. is this my tuner and are they costly for this model ?
  • 1 more comment
  • rayray123 Jan 21, 2008
    Thanks for the info glad you guys are hear :)
    My TV has vid 1 and vid 2 in and audio out how to i use the VCR as the tuner when i put the tv on tv mode still have snow ?
  • rayray123 Jan 22, 2008
    Thank you that worked :)
  • 2,335 Answers
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Posted on Jan 21, 2008
  • Jaime Hernandez Jan 21, 2008
    Connect the audio/video output from the VCR to the audio/video 1 or 2 from your TV. Do not use the tuner from the TV.
    Hope this works.
2 Suggested Answers
  • 3 Answers
SOURCE: Does the Sharp 32U-F810 TV have a digital tuner?
No it only supports analog. I'm pretty sure no CRT TV would be digital reception. Here is a link... Scroll down until you see the specs. First line is your answer: http://www.ciao.com/Sharp_32F540_CRT_TV_CRT__10021988#productdetail
Posted on Apr 28, 2009
What chanel do i put tv on to watch dvd movies
You are trying to work out how to watch a DVD movie on your TV
The DVD should be connected to your TV with Audio Video cables.
And it will most likely be connected to AV1 on your TV
The easiest way to find out would be to
  • Put a DVD in the Player and press play
  • Now the TV is probably in channel mode, so find the button on the TV remote that says TV/AV
  • now press this button TV/AV and it will scroll from TV channel to AV1, AV2 etc until you see the DVD picture.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | GPX D1816 DVD Player
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
May 21, 2009 | LG 42LG30 42 in. LCD HDTV
Turn on DVD power and Aiwa name screen is not displayed on television. rather it is just snow. no picture when dvd is playing. just snow. even though no loose connections. please help
i assume that your connection between tv and dvd is using an rf modulator. that means you dont have video input in the tv. if this is the case, set the tv channel to channel 3 or 4. let us know.
Apr 15, 2009 | Televison & Video
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
Jul 21, 2008 | Sanyo AVM-3259S TV
Bad reception on lower channels
Hello Moeggy,
Tuner of your TV set got defective and need to be replaced. Pls contact nearest Sony service shop for replacement of Tuner.
May 08, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-27V42 27" TV Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
