Question about Canon PowerShot A75 Digital Camera
Appears to work but no image recorded on card/black image
Lens goes in and out. LCD screen on the back works.
All functions appear to be available.
...But when picture is taken no image is recorded on the memory card.
This appears to be a frequent problem with this model. Can it be repaired and if so, for how much?
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Dec 21, 2009
SOURCE:
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Someone sat on my es-55 samsung camera, when i put it on an ink blot picture appears on the screen, this might be the lcd screen , the lens is okay as it still slides out.How do i fix it?
Hi
Does the 'ink blot' appear on any pictures you are taking or just on the Samsung ES55 LCD screen?
If it just appears on the LCD screen it's probably been damaged when it was sat on, and the only option would be to replace the LCD screen by contacting a Samsung service agent in your region.
If the 'ink-blot' image is appearing on the pictures you are taking then check the lens is clean - be careful not to extert to much pressure on the lens when it is retracted.
if the lens seems clean, as a last suggestion change memory card, or totally reformat the card that is in the camera - if the card has become corrupt the images may not be displaying correctly.
I hope one of these few suggestions sorts your problem.
Regards
David
Jan 17, 2011 | Samsung Cameras
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
No image on LCD while all else seems normal.
Go here:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCF717&news_id=161
Sony had a certain issue with the CCD chip on this camera. If it's this issue, they'll fix it free plus $20 until March 2010.
Dec 12, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
My screen is black. Can you help me?
I had a similar problem, but in my case teh screen was not entirely black but the image was very dar, like someone shut of teh lcd backlight, but the photos were coming ok (when checked on the pc). Showed it at repair sho, abd found out that one of the pcb supplying power to the backlight was not working and had to be replace. couldn't do much at home.
Apr 03, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Canon PowerShot A75 Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
