-   can't find it at all now on my acer laptop... it works online, on my msn, or anything...but it doesn't show at all... can't use it without using the internet things that can use it.
it can't work offline because it shows i dont have it, yet its built in.
-   Guest
Nov 10, 2008
-   what do I click on to get the download to install?-   Guest
You will need to know the type of camera that is installed (ie, Logitech, Bison, or Suyin and then click Laptops, and click on your model. The available drivers will display in the window. The are drivers for each cam type as well as the associated utility program. If you are not sure which cam you have then download all of them and install the driver and app for each brand seperately until you find one that works.
If you need additional help please post a reply and I will provide further help.
Hi, Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc. For these problem you can visit a link by just Click Here . For any other problem with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #3
posted on Jun 04, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have not the graphic driver for vista i cant found it what should i do ?
i click on my acer crystal eye webcam but it says the application has failed to start because image...
(More)
i click on my acer crystal eye webcam but it says the application has failed to start because image dll was not found
when i try to download effects it says that its not valid for winlocker 32 and that it doesn't have...
(More)
when i try to download effects it says that its not valid for winlocker 32 and that it doesn't have a publisher.
