Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Honeywell 6300B clicking noise
Just installed Honeywell RTH6300B Thermostat, it works great, but every time it turn on/off make the clicking noise, I have it in my bedroom, at night time it is realy ignoring by the noise. can some one tell me is it normal or I did some thing wrong. my 20 year old honeywell thermostat didn't make any noise at all. Thank you for any answer.
  • 1 more comment
  • Chris466 Feb 13, 2008
    I have the same thermostat and have noticed the same noise- I was wondering if something is wrong with the thermostat.
  • Anonymous Aug 19, 2008
    I have the Honeywell Pro 6000. We have the same problem.
  • Anonymous Jan 11, 2009
    we have the honeywell focus pro 8000 and are having the same problem. I can here two at once in my house at night. whew!
This is normal it is just the relay.
Posted on Jun 09, 2008
I have the same model, and am also experiencing the clicking.
Posted on Feb 22, 2008
The backlight is not working on my newly installed Honeywell RTH2310 thermostat.
Hello.The thermostat needs a COMMON wire.The letter C on the back of the thermostat.In the unit it runs there is a COMMON connection for that reason.I hope there is a spare wire strand to use because a lot of thermostats don't need a common to work (uses battery)but honeywell does.
Oct 31, 2010 | Honeywell Focus 6300B 5-2 Days...
Hi I honeywell,rth63oo b electronics thermo stat how do o change the accuracy from + - 1% to + - 3% Thankx
The following are the two manuals for ths product, I looked briefly and didn't see an answer to your wuestion. If you want to change the number of degrees between heating and cooling operation from 1 to 3 degress that can be found in the operating manual, under programming. 69-1723 - RTH6300B - Programmable Thermostat Operating Manual
69-1717 - RTH6300B Programmable Thermostat Installation Guide
Jul 20, 2010 | Heating & Cooling
Honeywell thermostat RTH6300b will not shut off at
I had this same problem with my 6300B thermostat. I did not see this when I installed the tstat and did setup for it the first time. If you go to page 16 of the install guide, there are instructions for setting up your tstat for your furnace and AC. The setting I had wrong was on page 20 of the guide. It defaults to a setting for a furnace/ac that is less than 90% efficient. When I changed the setting to a furnace that is more than 90% efficient, the fan not turning on or off problem went away. The setting on page 20 should be set to "3" if you have a more than 90% efficient furnace/ac. Hope this helps your problem
Jul 18, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Sep 19, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
RTH6300B Honeywell Thermostat
my air conditioning does not turn on at the time i want it on. previous owners had set timers for it to turn on, how do i re-set the timer as we do not want the timer on. we want to be able to turn it on and off as we please.
May 29, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
2,882 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
