Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Side by sise fridge
Does the coil heater get red how and for how long.
    President:
  • 1,314 Answers
Yes it varies for how long the unit should stay in defrost 30 Min's for every 8 hrs of compressor running time keeping in mind that the compressor don't cut on till the thermostat tells it to there also is a defrost thermostat that cuts the heater off when the coils reach a preset temperature
Posted on Jan 21, 2008
Samsung fridge coils frozen over on refrigerator side.
Not sure what the ohms should be,but ckeck coils for damage you may have a leak
Dec 07, 2013 | Refrigerators
Rs 265lbbp fridge is freezing everything fridge portion no ice on coils
This unit has a heater on the damper door. Sometimes the heaters go bad our just weak, causeing the damper door to freezer close. You can try thawing our damper by removing it to see if the issue happens again.
Aug 18, 2012 | Samsung RS265LBBP Side by Side...
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
Motor is on, freezer work but the refrigerator side does not get cold. It's barely cool.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem.....
Oct 04, 2010 | GE 21.9 Cu. Ft. Side-by-Side Refrigerator...
Back wall freezes up on freezer side while fridge side is too warm. fridge temperature stays between 60 to 70 degrees
Is the freezer fan working ? If not , control board probably bad . Pull refrig out from wall and remove power . Remove the 8" X 10" panel and you will see the main control board . Remove the blue plug with 3 larger wires . The sequence is : wire1 , wire2 , space , wire3 . Using a short piece of wire with both ends stripped about 1/4 " , insert the wire into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom rear for a red glow ( may take a minute or so ) . If you see a red glow , the main control board is bad ( the board you unplugged the wires from ) . If no red glow , then disconnect power to fridge , remove the jumper , and reinstall the blue plug and the panel .
Remove the food from the freezer section and remove the rear freezer panel inside the freezer . There you will see a round 1 " disk , clipped on top of the coils .Pt # WR60X10068 Defrost thermostat . At the bottom of the coils , you will see a heater . Pt # WR51X10042 Defrost heater . Replace both of these as the heater gets hot , and cuts off by the bimetal . he heater only has a screw on each side attaching it to the coils , and the bimetal just clips on . Easily repairable .
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRidge/freezer not staying cold
i would focus on the defrost heater or heaters behind the back wall of the freezer.this is kind of common.
Aug 06, 2009 | Refrigerators
Sizziling red hot coil in rear bottom of freezer (side by side)
That's the defrost heater. The defrost sensor has failed. The freezer has to be taken apart to find the sensor. It is usually round, with a couple of wires going to it.
Apr 27, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer no cooling
check continuity thro the fan motor and check it rotates freely
Oct 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Ge fridge
The defrost heater is a coiled heating wire inside a glass tube. The glass tube is usually not the easiest to see through, but you may be able to see a break in the wire. It would not hurt to apply 120 volts across the element. A good defrost element would then begin to glow red in just 10 or 20 seconds. Warranty is one year on parts and labor. Be sure to melt all frost off evaporator using a hair blower before reassembly.
Sep 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
