My office space heater will turn on for about 5-20 seconds and then it turns off. It will not turn on again for a while and if it does it only stays on for another couple of seconds - any suggestions on fixing this? It's electric and the light always stays on to show it's connecting to the outlet fine.
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
Was this helpful?
Yes
No
Popular Solutions for Honeywell HZ-325 KAZ Ceramic
Mr. Heater natural gas heater making a rushing noise when the pilot light is lit. When the burners...
(More)
Mr. Heater natural gas heater making a rushing noise when the pilot light is lit. When the burners light the pilot returns to normal?
After running normally for a minute or two my Comfort Zone CZ1500 fan stops, the heating element...
(More)
After running normally for a minute or two my Comfort Zone CZ1500 fan stops, the heating element stops and a code doFL appears? Regards Jack hawley hawley@xplornet.com
I changed out a gas valve to a carrier unit. gas valve model no. is 36e93. My question is. the gas...
(More)
I changed out a gas valve to a carrier unit. gas valve model no. is 36e93. My question is. the gas valve has terminals 5,1,4,2 and three. when I call the unit for heating i get the clicking from the 3 wire pilot. but the pilot line does not open. If i jump 1 to 4. the main gas will open but still no flame. how do i get that pilot line to open.
I'm working on a mitsubishi heat pump. Model no. muh09tw. Mr slim it was called. calling for heat on...
(More)
I'm working on a mitsubishi heat pump. Model no. muh09tw. Mr slim it was called. calling for heat on the inside wall unit. but nothing came on outside. I checked for 115v at the disconnect and had 115 volts. but nothing was coming on. it has no thermostat wires to see if it is even calling for heating. how do I check to see if it is calling for heating.
