FixYa.com
Tags:
Jenn-Air JCD2295HES Side by Side Refrigerator
Jenn-Air freezer leak (by 8 users)
posted by potterx2 on Jan 21, 2008
MyJenn Air (Model # JCD2295HES) side by side freezer leaks onto the floor. I've checked the bottom of the freezer compartment around the defrost drain and there is no water/ice inside the freezer, only a puddle on the floor. It happens sporadically (initially every 2-3 months, now once or so a week). Any suggestions/ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by spearso, posted on Jul 09, 2008
I have the same issue. Has anyone had success in fixing it themselves. Or has a repairman successfully fixed it for anyone?
Comment by rla501, posted on Jun 19, 2008
Same problem here. Just started recently...every couple of days my freezer pools with ice at the bottom and then water drips out onto the floor. Would like to try to fix this myself instead of paying big bucks to a repair co. (or buy a new fridge). Any advice? Thanks!
Comment by Kathandphil, posted on May 22, 2008
The same problem though almost every third day always at night. My freezer pools with ice at the bottom and I too can see water dripping from the door area, I am about to have my floors refinished and would like to have a solution before I do this.
Comment by Guest, posted on May 19, 2008
Same problem with leaking. I see the water at the bottom of the freezer and it puddles onto the floor.It's not constant, but it's a regular occurance. After cleaning the collections of dust from the bottom of the fridge and all around, the leak is the same.
Comment by Guest, posted on May 08, 2008
I have the same periodic leak and believe it is do to the automatic defrost cycle. I have found ice on the inside floor of the freezer and then took the inside back panel off and found the drain to be full of ice. I think this must have something to do with the humidity control as there is a opening between the freezer and the fridge behind the crisper.
Can you Help with these Refrigerators problems?
Refrigerators
Ice maker bar is not
Ice maker bar is not staying... Answer This...
Refrigerators
amana arb-190zc
amana arb-190zc not... Answer This...
Frigidaire Freezer won't freez...
My 6-year-old Frigidaire... Answer This...
freezer door ?
Freezer full of ice, door not... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 03, 2008
Have a leak coming from the condensate line I believe, which is on top of the unit and has a wicking system. The two metal kripping clams are loose. Do I need a special tool to tighten?
Comment by Lowla, posted on Mar 04, 2008
Water is dripping betwwen the gasket and panel on the lower corner edges of the freezer door. The leak is sporadic and causes a pool of water on the floor in font of the freezer. I can see it dripping from the corners of the door.
is the door a resevoir fopr the water dispenser? I have inspected the tubing that supplies water to the door and it is intact as far as I can see. I can/t see want happens inside the door. What should I do next?
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
